discretization of convective terms of Spalart Allmaras equations |
March 28, 2019, 07:34 |
Abolfazl
Rep Power: 10 |
Hi everyone.
I'm about to discretize the spalart allaras equation and add it into my compressible code based on Roe scheme. I was wondering can i use a simple first or second upwind for discretization of convective terms of spalart allmaras like incompressible flow or I should use the method of Roe!? thanks a lot |
March 29, 2019, 02:53 |
#3 | |
Abolfazl
Rep Power: 10 |
Actually I don't know. I know how i can use forward and backward discretization for convective term of spalart and this is all I know. I have no idea how I can use Roe for spalart! actually maybe I'm not asking the right question. I'm not well familiar with turbulence models. |
March 29, 2019, 06:00 |
Well, I tougth that, as you have a Roe scheme in your compressible code, you kind of knew it. For a general vector equation of the form:
your Roe scheme for the flux at the interface between cells L and R typically is: where: is the Jacobian of the flux (upwind altered by taking the absolute eigenvalues), the surface normal is assumed to point toward the R cell and the L and R states can be, in general, cell values (1st order) or suitably reconstructed values (2nd or higher order). Now, if you apply this to a scalar equation for with assigned mass flux, say , which is the first component of above, you get as flux: which actually is the upwind scheme in its most common version. In layman's terms, the point is that, for a scalar equation, you don't have a wave structure anymore, just a single eigenvalue, . |
April 7, 2019, 09:48 |
#6 | |
Abolfazl
Rep Power: 10 |
thank you for your kind reply. I checked the "computational fluid dynamics Vo.II" written by Hoffmann. I found that I can discrete the convective terms using a simple upwind scheme. but now I have another question. there is a term in Spalart Allmaras model: ? I know is but I don't get it how i can expand ! is the expansion for 2D like this? ? How like is the expansion for 3D? thanks a lot! Last edited by Abolfazl_cfd; April 7, 2019 at 14:01. |
April 7, 2019, 12:46 |
Filippo Maria Denaro
Rep Power: 73 |
No, Sij is the symmetric part of the velocity gradient. But what is more, stands in that fact the a turbulence model for incompressible flows does not necessarily can be extended as it is to compressible flows. Have a look here http://iccfd.org/iccfd7/assets/pdf/p...1902_paper.pdf |
April 7, 2019, 16:29 |
Discretization
Selig
Rep Power: 11 |
Unless you absolutely need to use the Roe scheme, I would suggest the AUSM+ scheme (or one of the variants.) It's easier to implement, cheaper in computational cost, and can be more accurate than the Roe scheme (I can't think of a case of where it's not.)
April 8, 2019, 03:54 |
#9 | |
Abolfazl
Rep Power: 10 |
Thank you for correcting my mistake. I toke a look into the paper and found it really helpful. specially the part about negative values of source term in Spalart Allmaras. Thank U. |
April 8, 2019, 03:59 |
#10 | |
Abolfazl
Rep Power: 10 |
Thank you for your precious advice. Actually I am working on immersed boundary method. years ago I tried to add my immersed code to a AUSM solver but some instabilities near the immersed boundary started to grow and after several attempts I gave up upon AUSM. But for Roe scheme it works properly. Thanks a lot. |
April 9, 2019, 04:47 |
#11 | |
Abolfazl
Rep Power: 10 |
finally I could write the spalart allmaras code. Although instead of Roe scheme, I used E-CUSP scheme, but the results in channel flow in Re=10000 are satisfactory. If anyone need the code, can send me an email. I would happy to share it and I hope it would help. moosavi.abolfazl@gmail.com |
A problem about using the Spalart Allmaras model | shiningkissss | CFX | 4 | April 23, 2017 23:28 |
CFX Spalart Allmaras turbulence models | aweizazuji | CFX | 9 | September 24, 2013 11:53 |
Spalart Allmaras Paper | Seroga | Main CFD Forum | 0 | April 7, 2008 03:48 |
About discretization equations for Axisymmetric | Dalitj | Main CFD Forum | 0 | August 15, 2003 00:50 |
Turbulent terms in the MRF equations | Francisco Saldarriaga | Main CFD Forum | 1 | July 22, 1999 17:49 |
