From the correlation tensor Rii to the three-dimensional spectrum E(k).
Like Tree2Likes
  • 1 Post By LuckyTran
Old   January 30, 2019, 04:56
Default From the correlation tensor Rii to the three-dimensional spectrum E(k).
luca mirtanini
lucamirtanini is on a distinguished road
Attachment 68071Hi all,
I cannot understand how the author (figure attached) passes from the correlation tensor Rii to the three-dimensional spectrum E(k).
In particular, I cannot understand how it can arrive to the definition of E(k) as integral on the shell surface.
Can you help me to understand the passages?
PS
Sorry for all my question, but it is difficult to me to find someone that can help me in the real life
lucamirtanini is offline   Reply With Quote
Old   January 30, 2019, 08:52
Lucky
Because the trace of phi is the kinetic energy at a given wavelength
You define the correlation tensor. Then you take its Fourier transform. And then you recognize that the trace of this thingy is the kinetic energy at a given wavelength (because you are a spectral space). That is, you recognize that since 8.1.3 gives the mean kinetic energy when you integrate phi over the entire wavenumber space. That means, integrating over a spherical shell gives you the kinetic energy at a specific wavenumber.
lucamirtanini likes this.
Old   January 30, 2019, 11:13
luca mirtanini
Why integrating over a spherical shell gives me the kinetic energy at a specific wavenumber?
Old   January 30, 2019, 11:17
Lucky
Well obviously integrating over a single shell means you are integrating at a specific wavenumber. What's not obvious is that this gives the kinetic energy.
Integrating over the entire sphere (or integrating over all wavenumbers) gives you the mean kinetic energy (via 8.1.3). Well not exactly, because it's off by a factor (the 3 instead of 1/2). The shell is one slice of this sphere (i.e. at one wavenumber). Hence it follows that the shell contains the contribution to the kinetic energy due to one wavenumber.
Going from 8.1.3 to 8.1.4 is natural. Maybe you need some calculus but understanding of high-school level geometry is all that is needed. The trick is recognizing the truth of 8.1.3. Getting to 8.1.3 is hard. Going from 8.1.3 to 8.1.4 should be easy.
Old   January 30, 2019, 12:28
luca mirtanini
I have understood. Thank you for your kind help
[waves2Foam] Trying to produce a frequency spectrum of a surface elevation time series MaximVZ OpenFOAM Community Contributions 1 January 19, 2016 13:16
Spectrum by using correlation function VictorCunha Main CFD Forum 0 June 20, 2014 14:26
spectrum: LES of a turbulent channel flow finally goes to turbulent liu OpenFOAM Running, Solving & CFD 6 November 1, 2011 02:00
Method to determine spectrum of turbulence? Walid Main CFD Forum 2 December 2, 2005 09:29
LES correlation and turbulent energy spectrum Fabian Main CFD Forum 4 October 18, 2005 03:04
