January 28, 2019, 07:03 |
Spectral interpolations
Marco Ghiani
Rep Power: 15 |
Hi everybody ,
I'm developing a CFD in-house code (Fortran) , The code is develop to simulate a polymer chain (macro-molecule) interacting with turbulent flow, using a coupling between DNS for the Navier Stokes equation and Langevin equation for polymer chain dynamic. the polymer chain is smaller than one cell , so we need to interpolate the velocity field in order to taking into account the hydro dynamic interaction between polymer and liquid from the letterature I've found that other researchers compute a spectral interpolation to the polymer trajectory... in the paper there is nothing other report (about this interpolation) but I have to implement into the code this kind of interpolation! Does some body said me where I can found some information about this interpolation ? and maybe some application to the CFD ... I didn't find nothing about ! thanks in advance |
January 28, 2019, 07:13 |
Filippo Maria Denaro
Rep Power: 73 |
Standard references for spectral methods:
https://www.springer.com/gp/book/ https://www.springer.com/la/book/9783540522058 |
January 28, 2019, 09:12 |
Marco Ghiani
Rep Power: 15 |
there is nothing free ? that book is readable over payment otherwise no
January 28, 2019, 09:26 |
First of all, is your DNS code spectral? Are the codes of the researchers you are referring to spectral as well?
Otherwise there might be no point in going spectral for the polymer interpolation |
January 28, 2019, 09:35 |
Marco Ghiani
Rep Power: 15 |
the code of the researchers is not mentioned in the paper ... is very poor of information .. they doesn't say the nature of the polymer (which polymer is used for the simulation)
Our code is no spectral .. but I have to try this interpolation. is it possible ? |
January 28, 2019, 09:58 |
Rep Power: 73 |
Free material is here https://people.maths.ox.ac.uk/trefethen/books.html
you can see that the spectral interpolation (it is nothing but a construction of a Fourier series) requires some constraints in the grid arrangement...on the other hand you could find useful to search for spectral elements. |
January 28, 2019, 10:15 |
Marco Ghiani
Rep Power: 15 |
oh thank you so much !
January 28, 2019, 15:28 |
Very generally speaking, It has no sense in using a spectral interpolation for something that is not spectrally accurate. You get garbage for everything below your grid step (or even more).
In practical terms, doing a spectral interpolation will require you to actually make a sort of spectral code |
January 29, 2019, 02:37 |
#9 |
Marco Ghiani
Rep Power: 15 |
which other accurate interpolation I may use ? now I'm just implement the triliear interpolation .. but it is so rough
January 29, 2019, 02:56 |
#10 |
Rep Power: 73 |
fvDOM spectral irradiance | edbarino | OpenFOAM Pre-Processing | 3 | August 25, 2021 04:29 |
Vortex method vs Spectral synthesizer for LES | HS | FLUENT | 1 | February 14, 2017 03:46 |
spectral methods for DNS and LES | ali | Main CFD Forum | 1 | January 16, 2006 10:47 |
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM | kenn | Main CFD Forum | 2 | July 18, 2004 19:28 |
Spectral Vs FEM | Khurram | Main CFD Forum | 0 | December 15, 2002 18:33 |
