Why collocated grid can be used for solving compressible flow?
Like Tree2Likes
  • 1 Post By sbaffini
  • 1 Post By agd
Old   January 18, 2019, 19:49
Unhappy Why collocated grid can be used for solving compressible flow?
TurbJet is on a distinguished road
Greetings,
As far as I know, there are some in-house codes (e.g., the code I am using) for solving high-speed compressible flows based on collocated grid (with finite difference of course), and they can generate good results without further efforts such as applying Rhie-Chow interpolation.
In contrast, in incompressible flow, collocated mesh will lead to some high-frequency oscillations in the solution due to the velocity-pressure decoupling (if I remember correctly), and either have to apply Rhie-Chow interpolation to fix it or just switch to staggered mesh.
I am confused : why collocated mesh can work for compressible flow, and yet it doesn't work for incompressible flow? I read some explanations saying that it relates to energy conservation. But I have no clue about the details.
Could anything provide some insights? Or maybe some papers I can refer to?
Appreciate it!
TurbJet is offline   Reply With Quote
Old   January 19, 2019, 04:33
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by TurbJet View Post
Greetings,
I am confused : why collocated mesh does work for compressible flow, and yet it doesn't for incompressible flow? I read some explanations saying that it relates to energy conservation. But I have no clue about the details.
Appreciate it!
The decopuling appearing in the incompressible flow solvers is due to the elliptic equation for the pressure that must enforce the divergence-free velocity constraint (have a look to the Peric & Ferziger textbook). Conversely, in compressible flow solvers this equation does not exist as the pressure is thermodinamic.
However, some oscillations can appear also in this case.
FMDenaro is offline   Reply With Quote
Old   January 19, 2019, 12:22
Under what circumstances would the compressible flow have oscillations?
Besides, do you have any references recommend on this topic?
Old   January 19, 2019, 17:46
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
It also depends from the specific compressible solver in use and the convective scheme. The preconditioned Roe flux difference splitting scheme has a Rhie-Chow like term for the pressure in the incompressible limit. Too drunk now to remember if it is in place also in general and/or for the non preconditioned case.
AliE likes this.
sbaffini is offline   Reply With Quote
Old   January 19, 2019, 18:27
That sounds about right; I've read a paper by S.K.Lele says that if shock waves is involved in the flow, collocated mesh will no longer work, so I guess the R-C interpolation has to be applied.
But I am just wondering, for low-speed compressible flow (e.g., subsonic, no shock waves), why the collocated mesh can work? Is it just because no Poisson equation as in incompressible flow?
Old   January 21, 2019, 06:26
sbaffini's Avatar
Paolo Lampitella
The continuity equation, no matter in which kind of solver, always include the divergence of the mass flux. If this is just evaluated centrally, I think you are going to have problems as well, no matter what.
I think compressible codes don't have such problems because they actually use upwinding/matrix dissipation for the mass flux in the continuity equation.
Rhie-Chow, in a sense, just does that, adds dissipation to the mass flux in the continuity equation.
Old   January 21, 2019, 12:17
Actually, for subsonic-to-transonic flow, the code I use can directly use 4th-order DRP scheme (which is an optimized central difference). But it's true that sometimes extra artificial filtering (dissipation) needs to be added to keep the solution stable.
Old   January 21, 2019, 14:24
agd
agd is on a distinguished road
If you are using a dispersion-preserving scheme such as that developed by C. Tam, I would be surprised if there is not some artificial damping added into the code to maintain stability. It may be in the form of explicit damping or a high-order filter to remove spurious oscillations, but it will be there. All central difference schemes require some form of damping/upwinding/filtering as the Mach number increases to account for the hyperbolic nature of the equations of motion.
TurbJet likes this.
agd is offline   Reply With Quote
Old   January 21, 2019, 16:24
I am using DRP scheme developed by C.Bogey & C.Bailly. I do use filtering. What I meant in the previous thread is just that there are some cases I can live without it.
Um, so I guess it is the filtering eliminates those oscillations so that they do not show up? Namely, the collocated mesh still introduce oscillations (same as in incompressible flow) but just killed by filtering?
Or it is the different oscillations you are talking about?
Old   January 21, 2019, 16:39
agd
No, that's it. The filtering removes the oscillatory behavior that would tend to develop. It serves the same function as artificial viscosity, or added damping, or upwinding. It is just a different approach to the same end state.
Old   January 21, 2019, 16:50
Generally, one analyses the number of zero in the Fourier symbol of the operator. If more than the fundamental mode is found (more than one dimension), the zeros are at the Nyquist frequencies implying a possible oscillations in the solution. The adoption of filtering aims to eliminate such modes.
Old   January 21, 2019, 16:57
Now it makes me wondering if anyone adopt such approach to incompressible (introducing the filtering and without the Rhie-Chow interpolation) to eliminate the oscillations from collocated mesh?
Also, assuming I am using staggered mesh, is the artificial viscosity still needed?
Old   January 21, 2019, 16:59
So you mean the filtering kills all possible oscillations, no matter where they stems from?
Old   January 21, 2019, 17:04
Well, it depends on the type of filtering, some filter can totally remove high wavenumbers components other types can smooth the content...
collocated grid, compressible flows, incompressible flows
Compressible flow or incompressible flow equation?? ulfaazmi Main CFD Forum 0 July 10, 2018 06:48
compressible vs incompressible flow Nick R Main CFD Forum 1 March 15, 2017 12:29
What is the difference between Non-staggered and Collocated grid? carl jung Main CFD Forum 2 January 23, 2017 15:39
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Compressible Flow Modelling? yeo FLUENT 4 March 7, 2003 08:08
