simulating Creeping flow with Reynolds number 5e-9 |
December 19, 2018, 17:54 |
Rep Power: 8 |
Hi every one
I have to simulate the steady creeping flow with Reynolds number 5e-9. I have managed to simulated similar case with Reynolds number 0.1 in fluent, but Fluent has convergence problem as Reynolds number decreases to 1e-7 (Fluent converged in one iteration). I have read the post Simulating Creeping (Stokes) Flow in OpenFOAM where the creeping flow with Reynolds number 0.001 can be simulated by Openfoam. But I do not know if Openfoam can simulate the Reynolds number 5e-9 I want? If fluent and Openfoam can not simulate the steady creeping flow with Reynolds number 5e-9, any other CFD softwares can do it? Thanks Fan |
December 20, 2018, 00:50 |
Lucky
Rep Power: 66 |
Creeping flows are a piece of cake for both Fluent and OpenFOAM.
Convergence in 1 iteration just means you need to turn off the convergence monitors. If you have divergence problems then you might need to tweak some solver settings, but there's no limitation or reason why Fluent/OpenFOAM can't solve creeping flows. |
December 20, 2018, 04:05 |
Rep Power: 8 |
Hi, I agree with LuckyTran. In OF, I have solved several problems disabling convective term (i.e.solving stokes equation). For a such low Re, you can have some issues related to the viscous stabilty, which forces your time step to be lower, but theoretically there are no reason for which they will not work!
December 20, 2018, 07:59 |
Rep Power: 8 |
Hi LuckyTran
It works after I turned off the convergence monitors. |
December 20, 2018, 08:10 |
Rep Power: 8 |
Hi AliE
Could you please tell me more about how to disable convective term in fluent? |
December 20, 2018, 08:11 |
Rep Power: 8 |
Well unfortunatelly I cannot be useful here, sicne I have done it only in OF. Not sure you can change the code at this level in fluent. Maybe LuckyTran in more expert than me in fluent!
December 20, 2018, 12:12 |
Lucky
Rep Power: 66 |
Disabling the advective/convection term only is not really a feature in Fluent. You would have to find a nasty workaround. I would recommend to use OpenFOAM if you want to solve the Stokes equations. Fluent solves the compressible Navier-Stokes and it's really hard to get it to do anything other than that.
December 20, 2018, 12:45 |
Filippo Maria Denaro
Rep Power: 73 |
Maybe using the NITA method for incompressible flows and setting an high value for the kinematic viscosity using the characteristic velocity of 1 m/s and the lenght of 1m you have implicitly this feature.
creeping flow, very low reynolds number |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 08:48 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 13:55 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 11:27 |
Difficulties in solving a high Reynolds number Flow? | wowakai | Main CFD Forum | 10 | December 29, 1998 14:46 |
