Rhie-Chow interpolation in Fractional Step Method |
December 7, 2018, 05:58 |
Rep Power: 8 |
Dear CFD friends,
I am going a to add the fractional step method by Kim and Moin (JCP 1985) in my FVM code (which actually has collocated PISO/SIMPLE + unstructured and body fitted grids) and I am collecting some information. I have already experienced this method and I know it quite well. The only thing that I am missing a bit is how Rhie-Chow interpolation is implemented in such framework. I have an old code where I can argue something about it, but there is a lack of refereces and I am not 100% sure. Have you experience with this? How do you perform this operation? (i.e. how you correct mass fluxes at faces to avoid pressure checkboarding?) I have super clear both theory and practice in FVM, thus don't be shy, you can give me "high level" details Thanks a lot! |
December 7, 2018, 13:48 |
Filippo Maria Denaro
Rep Power: 73 |
I analysed the RC interpolation in one of my paper but I did not use it as I worked in a different manner where no additional dissipation-like terms are introduced.
Have you already read this paper? https://www.researchgate.net/publica...ar_Coordinates |
December 9, 2018, 08:39 |
Rep Power: 8 |
Hi Filippo, Good sunday! Yes, I know this reference, but I do not use curviliear coordinates and it is diffucult apply it to my current implementation.
December 9, 2018, 08:48 |
#4 | |
Rep Power: 73 |
Try to read the guide of openfoam where the RC is introduced and the references they cite. Of course, also the Ph thesis of H. Jasak should detail the interpolation on unstructured grid. Some further papers https://core.ac.uk/download/pdf/25787519.pdf https://onlinelibrary.wiley.com/doi/...2%3E3.0.CO;2-X |
December 9, 2018, 08:56 |
Rep Power: 8 |
Thanks, I wiil! I know well the OF interpolation used with PISO alghoritm and actually I have the same in my PISO solver.
Looking at one of my old codes using FSM, I have found out a different implementation and this makes me think that maybe the things are not exactly the same using fractional step. But maybe they are not that much This why I am curious to know other users'opinion on this topic! |
December 10, 2018, 08:16 |
#6 | |
Rep Power: 73 |
As I wrote before, I developed a different procedure, however the R-C interpolation extended to unstructured grids was described here https://www.sciencedirect.com/scienc...2199910096546X |
Fractional Step Method and SIMPLE | Ha Lim Choi | Main CFD Forum | 14 | June 14, 2017 11:17 |
Fractional Step Method with Dirichlet Pressure Boundary Conditions ? | o_mars_2010 | Main CFD Forum | 7 | October 28, 2013 04:40 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Comparing between the Fractional step method and the SIMPLE method | ghlee | Main CFD Forum | 1 | April 10, 2012 16:59 |
SIMPLE family and Fractional Step Method | Geon-Hong | Main CFD Forum | 2 | April 5, 2010 18:05 |
