Is that practically possible analyze furnace via CFD? |
August 26, 2018, 08:11 |
Jaesan Yoon
Rep Power: 9 |
Yes, I know, thermal radiation and convection effect could analyzed.
(attempt itself is possible, and I use FLUENT 18 now.) However, my question is that Target furnace is about 1100 degree of Celsius and Input gas is about 7~800 degree while variation temperature of furnace heater is 50~80 degree at least. Current target of temperature variation of furnace is less than +-5 degree of Celsius for specific position which is mechanically moved slowly. I thought both improvement of the temperature variation and CFD correlation seem difficult. Is there any idea about this? (for better correlation and improvement itself) From my literature survey, CFD analysis with very simple geometry furnace already shows discrepancy for more than 2~3%, about 20~30 degree at 1000 degree. Also, re-production of variation of heater temperature is not easy. I hope some one recommend reference paper or method representing high temperature furnace with high accuracy in complex geometry |
August 27, 2018, 04:10 |
Uwe Pilz
Rep Power: 15 |
I think you cannot expect this degree of match. The main problem is that you cannot cover all the aspects of the reality in a CFD model.
I see two main reasons for doing CFD 1) You want to explore something. Therefore the simplest geometry and my be very simple boundary conditions are adequate. Beside this, all the physics should be reduced to the values you need to evaluate. You have to adapt your experiments to that simple case. In this case, the match between experiment and calculation should be very good. 2) You want to improve an existing facility. In this case the match doesn't need to reach the last few percents. It is far more important, that you see what happens if you change something. You need (more) to know the changes instead of the absolute values. It is mostly possible to calibrate your predicted result with the measuring values form the unchanged case.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
August 27, 2018, 05:19 |
#3 | |
Jaesan Yoon
Rep Power: 9 |
Unfortunately, correlation from using simple geometry is not available from my company; correlation via real facility is only option And this is why I asked reference cases that existing CFD case or paper reproducing +-5 degree level variation in 1000 degree environment. Requirement for that case is reducing +-5 degree variation in 1000 degree level furnace, and I think CFD reference model of mine should give enough fine confidence level for temperature variation. |
August 27, 2018, 05:48 |
Uwe Pilz
Rep Power: 15 |
You did not understand me fully:
I recommend that you take the measuring values to calibrate the results from your cfd results. Therefore ist is not necessary to use an oversimple geometry and physics.
August 27, 2018, 05:52 |
Jaesan Yoon
Rep Power: 9 |
Oh I understood. Still, I could not convince that guys in the furnace lab give appropriate data, but it is worth to try it. Thanks again.
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
PC vs. Workstation | Tim Franke | Main CFD Forum | 5 | September 29, 1999 15:01 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 11:44 |
