Computing the energy spectrum of a turbulent channel flow
Like Tree1Likes
  • 1 Post By FMDenaro
Old   August 15, 2018, 02:04
Default Computing the energy spectrum of a turbulent channel flow
David
Olympical is on a distinguished road
Hi Guys,
I am a newcomer to the world of computational fluid dynamics so please bear with me. I have been playing with a channel flow similar with periodic boundary conditions in the x and z direction. Now I am trying to compute the 1D and 2D energy spectrum of the channel. As far as I understand it simply a fourier transform for the time series of the time series of the directional velocities for the 1D case. Is this the case ? I have also outputted the results of my simulation every 2000 steps, would I need to have more frequent output for the purposes of the energy spectrum?
Thanks so much for your help
David
Olympical is offline   Reply With Quote
Old   August 15, 2018, 04:35
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Have a look to similar questions, for example
Energy spectrum-wrong spectrum shape
FMDenaro is offline   Reply With Quote
Old   August 21, 2018, 05:31
David
Thanks for the reply, sorry I missed the previous post which I have now gone through and it has been an immense help.
One question that pops up when I am trying to perform these calculations myself. If I am trying to compute the spectra along Kx, I am taking a constant-y plane then performing fft over the time series of each z value correct? What I am confused about is that each z value also has a corresponding x values so am I performing the fft at each grid point in the y-plane? If it's only for each z values then what do I do with the points along a certain z.
Thanks very much for your patience, I am still quite new to CFD in general so these questions might seem a bit basic.
Old   August 21, 2018, 05:40
The order can be the following:
1) fix a time and use the velocity field at this time
2) fix a position y (distance from the wall)
3) Compute the spectra in the plane xz, that is the spectra along kx (kz) for all the discrete positions z (x) of the grid.
4) Perform the ensemble averaging in z (x) of the spectra along kx (kz)
5) Repeat from 1) at a different time
After you have a sufficient sample of spectra in time, perform the ensemble averaging in time.
As final results you can show the spectra Euu,Evv,Eww both in kx and in kz.
watermelon likes this.
How to calculate Reynolds shear stress of a fully turbulent channel flow yansheng STAR-CCM+ 1 March 8, 2016 18:35
problem with DNS turbulent channel flow huangxianbei OpenFOAM Running, Solving & CFD 4 March 5, 2014 00:39
turbulent channel flow mn1363 Main CFD Forum 1 January 14, 2013 14:05
LES of a turbulent channel flow stays laminar liu OpenFOAM Running, Solving & CFD 2 May 27, 2010 14:53
LES correlation and turbulent energy spectrum Fabian Main CFD Forum 4 October 18, 2005 03:04
