June 29, 2018, 11:22 |
Flow over a plate
Vivek
Rep Power: 8 |
Hi everyone,
I have one clarification about flow over a flat plate. I had searched in online but i am not clear till now. Why the leading edge of flat plate has sharp corner in the simulation of flow over a flat plate ? Why not other shapes? Thanks in advance!! |
June 29, 2018, 12:31 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
In the theory of developing boundary layer (Prandtl equations), the point x=0 is a point of singularity in the solution. When we solve numerically, the spatial discretization cannot distinguish exactly on a node where the origin is. If you want to consider a smooth body describing the leading edge, this is developed in a different theory for the BL. |
June 29, 2018, 13:07 |
#3 | |
Vivek
Rep Power: 8 |
June 29, 2018, 13:33 |
#4 | |
Rep Power: 73 |
No, what I mean is that the BL theory over a flat plate consider really a semi-infinite plat with zero thickness. On the other hand, on a numerical grid of size h, you can set the first node with no-slip condition but owing to the discretization that does not determine exactly the singular point in the origin. If you want to describe a slender flat with a rounded leading edge, the standard theory of Prandtl should be modified by the developing boundary layer over the rounded leading edge. If I am right, that theory was developed by Hinze who described an exact solution for small values of x. |
flat plate, sharp corner |
Flow over a heated flat plate: non-physical solution | Sushobhan | OpenFOAM Running, Solving & CFD | 0 | May 5, 2018 00:43 |
Coherent structure for LES simulation of flow past plate with Re=50000 | Bashar | OpenFOAM | 1 | December 22, 2016 08:50 |
flow over a plat and study of temperature distribution in plate and flow | Sufyan | FLUENT | 0 | October 16, 2012 04:38 |
results for flow past flat plate normal to flow | lisa | Main CFD Forum | 2 | August 30, 2005 17:36 |
Supersonic flow over flat plate - best model | Chris Rand | FLUENT | 4 | October 3, 2000 07:58 |
