A high order curvilinear mesh generation(converting) tool is strongly recommended
Like Tree1Likes
  • 1 Post By hyperman
Old   June 22, 2018, 09:16
Default A high order curvilinear mesh generation(converting) tool is strongly recommended
bell
hyperman is on a distinguished road
A high order curvilinear mesh generation(converting) tool, which is named 'GRIDer', is strongly recommended:
For high order numerical solver, such as DG, high order curvilinear mesh is necessary. If 1st straight-edge mesh is used for high resolution method, non-physics flow phenomenon would appears.
A software named 'GRIDer' is found to convert 1st straight-edge mesh into curved-ede mesh for arbitrary cell type, such as triangle, quad, tet, prism, pyramid.
INPUT: CGNS type of 1st straight-edge mesh && IGES CAD geometry model.
OUTPUT: GMSH format of curved mesh.
you can get it from
https://github.com/grider2016/grider
arjun likes this.
hyperman is offline   Reply With Quote
Old   June 22, 2018, 09:39
Praveen. C
praveen is on a distinguished road
Looks like you are the author of this software. Do you have a description of the method used to generate the high order mesh from the linear mesh ?
praveen is offline   Reply With Quote
Old   August 7, 2018, 18:30
Zach Davis
RcktMan77 is on a distinguished road
That's great, but what do you do about the very thin elements used to resolve the boundary layer around highly curved surfaces?
RcktMan77 is offline   Reply With Quote
Software to mesh using high order element with unevenly spaced interpolation node lzhaok6 Mesh Generation & Pre-Processing 4 August 14, 2016 01:01
Visualizing mesh regions with high courant number? Endel OpenFOAM 2 August 20, 2013 04:57
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
2nd order boundary conditions for 2nd order discretization? quarkz Main CFD Forum 30 December 26, 2011 08:12
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
