June 6, 2018, 11:20 |
Droplet simulation inside the channel
Arash
Rep Power: 11 |
Hi every one
I am going to do a DNS simulation of a fixed droplet inside the channel with Phase Field method but i don't know how to keep the droplet fixed? does anyone have an idea or know a paper which is worked on the the droplet kept fixed? I appreciate your suggestions. Thanks |
June 7, 2018, 05:48 |
#2 | |
wujun
Rep Power: 14 |
June 7, 2018, 07:22 |
Rep Power: 14 |
Is it a horizontal or a vertical chanel?
For vertical i would know a possible solution.. But horizontal .. hmm |
June 7, 2018, 07:28 |
Arash
Rep Power: 11 |
thanks for your reply but i should use Phase field model to capture interface (actually i have a diffuse interface not sharp)
June 7, 2018, 07:29 |
Arash
Rep Power: 11 |
June 7, 2018, 07:37 |
Rep Power: 14 |
I dont understand your problem very well...
You have a diffusive droplet inside a horizontal chanel that needs to be fixed in position. Can you provide more information, is the interface tracked? Maybe a sketch can help For a VOF type simulation in a vertical pipe it would be essentially a controlling problem to keep the position at a fixed heigth.. Regards |
June 8, 2018, 00:01 |
wujun
Rep Power: 14 |
[QUOTE=a.hajisharifi;695046]thanks for your reply but i should use Phase field model to capture interface (actually i have a diffuse interface not sharp)[/QUO
I don't understand you said the interfaces. |
droplet simulation, multiphase modelling, phase field |
Fluent Open Channel Simulation | ahammack | Fluent Multiphase | 0 | October 12, 2016 13:58 |
Simulation of charge redistribution of a droplet due to impact on solid | multiphaser | Main CFD Forum | 0 | October 5, 2016 05:04 |
Open channel flow simulation using VOF | rsaha | FLUENT | 5 | April 10, 2016 18:28 |
Problems about phase-change simulation inside a heat pipe | 6863523 | FLUENT | 7 | October 14, 2014 11:07 |
Need help on single droplet simulation | khunyeu | FLUENT | 0 | June 3, 2014 01:23 |
