Boundary conditions for pressure-correction method
Like Tree3Likes
  • 1 Post By FMDenaro
  • 1 Post By selig5576
Old   May 22, 2018, 03:19
Default Boundary conditions for pressure-correction method
Moshe De Leon
moshe is on a distinguished road
i want to learn about boundary conditions for a compact Poisson stencil. after searching through this forum it seems that people are using ghost points when handling pressure BCs for a collocated arrangement (cf. pressure boundary conditions for collocated grid for Navier-Stokes) is there a way that avoids having a layer of ghost points? this ghost point approach seems to have difficulties. After some google searching I found some slides that talks about pressure boundary conditions for a compact stencil, but it seems to be incorrect (slide 5 of https://www3.nd.edu/~gtryggva/CFD-Co...re-15-2017.pdf) The professor explicit sets the bc rather than modifying the PPE at the boundary.
moshe is offline   Reply With Quote
Old   May 22, 2018, 04:25
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
There is no need to prescribe ghost nodes, you can find similar post in this forum
moshe likes this.
FMDenaro is offline   Reply With Quote
Old   May 22, 2018, 13:47
Default pression eqn
Selig
selig5576 is on a distinguished road
Attached is a complete pressure bc based on Dr. Denaros approach. I have not tested this as I have switched to a staggered based solver since I was unfortunately never able to get my collocated solver to work properly.
moshe likes this.
selig5576 is offline   Reply With Quote
Old   May 22, 2018, 13:56
On staggered grid this issue is also more simple, a good explanation is given in the JCP paper of Kim and Moin on the fractional step method.
selig5576 likes this.
Old   May 22, 2018, 14:02
Default pressure bc
Moshe De Leon
i think this formulation is wrong as you only have 1 diagonal entry in the iteration routine, no?
Old   May 25, 2018, 13:47
Default thread bump
Moshe De Leon
don't mean to bump this, but when we write the laplacian operator at i = 2, we iterate at i = 1, which means we only have 1 diagonal term since the other diagonal term dpdy|j=2 is moved to the right-hand side.
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
