May 10, 2018, 04:48 |
Choice Turbulence Model Flow around Airfoil
Massachusetts
Rep Power: 11 |
Hi to all,
I have to perform a simulation (to calculate the Cl) of an airfoil at low angle of attack and high angle of attack to calculate the Clmax. I thought to use the k-e turbulence model for the first simulation because i know it performs well for not too complex flows, not severe pressure gradient and attached flow. Am i right? Furthermore I don't know if the same model could work good also for the Clmax. Maybe should i run a LES or use a k-w model? Or is there another turbulence model that work better in this case? So, my final question is, which practice do you follow to best calculate the Cl in my situation? Many Thanks for help |
May 10, 2018, 04:51 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
You could try a DES apporach... |
May 10, 2018, 05:21 |
Massachusetts
Rep Power: 11 |
May 10, 2018, 05:28 |
Rep Power: 73 |
Low Re Turbulence model VS Low Re flow and Turbulence Modelling background | pchoopanya | Main CFD Forum | 4 | May 10, 2018 12:05 |
k-ω turbulence model for flow and heat transfer | modest_may | CFX | 16 | March 30, 2018 09:40 |
Airfoil lift and drag using k-kl-omega turbulence model | hylleman | OpenFOAM Running, Solving & CFD | 6 | June 17, 2016 16:10 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
validating turbulence model on flow around a car | Pedro | CFX | 1 | February 20, 2008 17:32 |
