Difficulties in meshing
Like Tree1Likes
  • 1 Post By piu58
Old   April 15, 2018, 13:54
Default Difficulties in meshing
Jack Alderson Taggart Penny
Big Kahuna is on a distinguished road
I am trying to simulate a Hagen Poiseuille flow inside a tube (a pipe). I obtained all my codes from http://files.the-foam-house5.webnode...pter4_Pipe.pdf. The person who wrote the codes had a single pipe through which fluid flows. What I am trying to do is to attach a second pipe (with a smaller diameter) to the the tail end of the first pipe and watch the fluid flow from the first pipe into the second pipe, and since the second pipe is narrower, I was hoping to see fluid velocity increase as it enters the second pipe. What I did was modify this guy's blockMesh code to reflect the fact that there are now two pipes, not just one. But when I ran the simulation, the fluid filled both pipes at the same time! It wasn't a flow from pipe 1 into pipe 2 -- it was a simultaneous inflow of fluid into both pipes. Is this because I did not create a "hole" at the tail end of pipe 1 and a "hole" at the front end of pipe 2? Is this absence of "holes" in the pipes that is causing the program to think that the two pipes are distinct objects rather than one continuous object? I don't know how to create "holes" in pipe 1 and pipe 2. All I want to do is see fluid flow from pipe 1 into pipe 2 and the fluid velocity increase as it enters the narrower pipe. Any advice, please?
Big Kahuna is offline   Reply With Quote
Old   April 16, 2018, 01:42
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I don't know your case, but the normal, straightforward simulations are such that the pipe(s) are always filled with fluid. The simulation only starts the flow. It is quite normal then, that you get a fluid velocity everywhere immediately.
he case you described need a two phase simulation, which is more complicated.
Big Kahuna likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
mesh 3d
[ANSYS Meshing] Meshing strategy for External Flows Hybrid ANSYS Meshing & Geometry 0 January 24, 2012 15:27
Reg difficulties in meshing the geometry...Urgent arunraj ANSYS Meshing & Geometry 0 August 27, 2011 00:25
[ICEM] Meshing difficulties (Hexa meshing, O-Grid, etc.). Even possible to be resolved? JasonLam ANSYS Meshing & Geometry 0 April 19, 2011 21:08
Urgent help, help pl for meshing problem Shashi FLUENT 8 October 8, 2008 12:24
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
