Where can I find files for performing benchmarks? |
April 10, 2018, 04:55 |
The_Immortal
Rep Power: 10 |
Hi there!
Guys, I'm wondering where can I find ANSYS Fluent files for perfoming Flow through a combustor (combustor_12m) (Fluent 17, Windows) ? I took a look into ANSYS Customer Portal (Home > Training & Support > Benchmarks > ANSYS Fluent Benchmarks) but found there only files for Fluent 16 and they're all undownloable... Any ideas? Thank you! |
April 10, 2018, 05:07 |
Alex
Rep Power: 49 |
https://support.ansys.com/AnsysCusto...ent+Benchmarks
Sure they are "v16" but nothing prevents you from loading them in any newer version of Fluent. If you can see the files, this means you are logged in as an Ansys customer and should be able to download them. Check your browser settings (adblock, noscript, popups etc.) or try a different browser. |
April 10, 2018, 05:22 |
#3 | ||
The_Immortal
Rep Power: 10 |
April 10, 2018, 06:14 |
Alex
Rep Power: 49 |
I am not sure if they have newer version of the benchmarks. These were to ones I used with Fluent v18.
The benchmarks are just cas and dat files. You can load them with newer versions of Fluent. Fluent v18 (or v17) can load cas files that were saved with v16. The other way round might not work. |
April 10, 2018, 09:39 |
Alex
Rep Power: 49 |
Type in "parallel timer usage" in the TUI. Without the quotation marks.
April 10, 2018, 10:36 |
The_Immortal
Rep Power: 10 |
Sorry for my stupid questions. I'm totally a newbie in ANSYS and all I need is to get the benchmark results actually...
As far as I get I also can use flbench.bat for getting results, right? |
April 10, 2018, 16:16 |
The_Immortal
Rep Power: 10 |
Guys, please could you tell me is it possible to launch flbench.bat under Windows?? I need to get the "Core Solver Rating".
What I did: 1. Copied files aircraft_wing_2m.cas.gz and aircraft_wing_2m.dat.gz into c:\Program Files\ANSYS Inc\v172\fluent\ntbin\ 2. Launched in cmd: Code:
c:\Program Files\ANSYS Inc\v172\fluent\ntbin>flbench.bat fluent aircraft_wing_2m -v 3d -a win64 -path "c:\Program Files\ANSYS Inc\v172\fluent\ntbin\win64\" Code:
Unxpected behaviour: Files\ANSYS. Thank you! P.S. I'm wondering is there an instruction how to finally launch it??? |
April 10, 2018, 17:41 |
#9 |
Alex
Rep Power: 49 |
"core solver rating" instead of "benchmark results" as a keyword would have been helpful
IIRC, Ansys defines its core solver rating metric as the amount of runs per day with 25 iterations each. You can calculate it yourself from the timer output. No idea how to batch-run the benchmarks in windows, sorry. |
[OpenFOAM.com] v1706 on Windows+Docker: Can't find the files | Atomic_Sheep | OpenFOAM Installation | 6 | September 21, 2017 09:18 |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 06:38 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
