Geometry of porous medium
Like Tree1Likes
  • 1 Post By ashokac7
Old   February 21, 2018, 00:20
Default Geometry of porous medium
The Shard
theshard is on a distinguished road
How do I make a geometry for a porous media and then mesh it? What softwares can I use?
theshard is offline   Reply With Quote
Old   February 21, 2018, 02:28
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
You can do this in any CFD software like Fluent or Star-CCM+ etc. For the geometry you only have to extract outside surfaces. Create a separate region where porous medium is there. We assign it a porous media and give Inertial and Viscous coefficient values.
P.S. Try reading some papers and then ask more appropriate question.
lcarasik likes this.
ashokac7 is offline   Reply With Quote
Old   February 21, 2018, 07:11
Default I'm trying to construct the internal geometry of the membrane/porous media itself
The Shard
I'm trying to construct the internal geometry of the membrane/porous media itself. I know that you can create a porous media using the method you mentioned but that is not my question.
Old   February 21, 2018, 22:50
Lane Carasik
lcarasik is on a distinguished road
Like ashokac7 stated, Star-CCM+, ANSYS FLUENT, ANSYS CFX, OpenFOAM, others can model this program. This is a very generic CFD problem (you can use a unit cell representation).
lcarasik is offline   Reply With Quote
Old   February 22, 2018, 01:41
Red face
ashokac7's Avatar
Ashok Chaudhari
This is really your choice though. Like if only pressure drop is concerned to you it is not advisable to model the whole porous structure. Porous approach is sufficient for that. But if you want to model each and every layer/membrane in porous media, that's tricky. Think in terms of resource you need for that. Like between two adjacent layers, we have to put atleast 4-5 layers in between so that CFD have some domain to make calculations there. This is also on the top of refinement we have to do to capture exact surface feature which also increase the mesh count exponentially. And this is why porous coefficient approach come to existence, isn't it?
Old   February 22, 2018, 02:01
Default Porous Media
The Shard
I'm trying to work with many factors including pressure drop. I have the pore diameter, length of pores, number of pores in given area and thickness of membrane. I'm encountering a problem when I construct the geometry because the diameter of the pore is in nanometre (1.8 nm) and the area is in mm(0.8mm*0.8mm). I tried working this out in Catia but in vain. Even if if do model it in these dimensions, I guess it will pose meshing problems?
I want to know how to approach this situation.
Old   February 22, 2018, 03:25
Cool
ashokac7's Avatar
Ashok Chaudhari
Clearly you can not easily model such problem as it is in CFD. Diameter is too small. Instead try to calculate the porous coefficients for your case. refer this https://en.wikipedia.org/wiki/Fluid_...h_porous_media
Darcy's law is there to deal with these cases.Even if you are able to create the geometry in Catia how will you model it here. The factors you have maintained will be taken care by porous coefficients.
geometry, membrane, meshing, porous domain
UDF for Sorption in Species Transport through Porous Medium Kosch Fluent UDF and Scheme Programming 6 October 21, 2020 18:46
Heat transfer through porous medium myworkcfd FLUENT 0 June 6, 2017 09:32
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 07:32
Lack of local thermal equilibrium in porous medium Chander CFX 4 March 4, 2012 05:07
[DesignModeler] geometry and porous medium kmgraju ANSYS Meshing & Geometry 0 December 20, 2011 11:58
