February 1, 2018, 23:22 |
Validating and verifying CFD simulations
Oluwaseun Adedeji
Rep Power: 10 |
I am doing a CFD simulation of a flow system in a very unusual geometry. This means, not much is understood about the hydrodynamics of the system and there is limited (if any) experimental data available to validate the CFD simulation. Besides experimental data, what other ways can one proof that a CF result is valid? Also, if you know any, kindly suggest papers or literature you know that have done CFD simulations of not-too-common systems and have validated them with minimal experimental data but also with some more substantial proof. Thanks |
February 2, 2018, 01:31 |
Uwe Pilz
Rep Power: 15 |
AT least you may perform simulation with the same physics, but simpler geometry (for which you have reference data).
If you use the same principles in simulating your case, the deviation should be in the same range. There is always an additional problem of course, the problem with meshing complicated geometries. To overcome this, try different meshing strategies and prove, that the mesh doesn't introduce a large amount of deviation.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) Last edited by piu58; February 2, 2018 at 02:53. |
February 2, 2018, 02:34 |
#3 | |
Oluwaseun Adedeji
Rep Power: 10 |
Thanks for your reply. Is there a literature you would recommend ? |
February 2, 2018, 02:55 |
Uwe Pilz
Rep Power: 15 |
It depends on your problem which I don't know.
Well understood / measured systems are flow over a plate and past a cylinder or sphere. You find tons of literature for this. Measuring values you may obtain from the old books of Ludwig Prandtl or Hermann Schlichting.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
February 2, 2018, 03:04 |
Violet
Rep Power: 10 |
Can you give us a little bit more information about your geometry? And what you are trying to measure? Without a problem statement we cannot help you other than give you general suggestions which would not be much of a help. In that way, perhaps we can also help give suggestion on the experimental part.
Oluwaseun Adedeji
Rep Power: 10 |
Thanks again for your response
February 2, 2018, 03:20 |
#7 | |
Oluwaseun Adedeji
Rep Power: 10 |
February 2, 2018, 03:33 |
Uwe Pilz
Rep Power: 15 |
You have a two pahse problem, air and water. For this the easiest point to start is the ascending bubble. You don't have external forces beyond gravity there, but it is the first example I would try to solve. There is an excellent report by Hysing about this.
hydrodynamics, model validation |
