CFD simulation of Rocket nozzle flow separation (Turbulence modelling issue) |
January 1, 2018, 03:20 |
Bal Krishan
Rep Power: 9 |
I am working on the CFD simulation of supersonic rocket nozzle flow separation with turbulence modelling (2D axisymmetric). I have tried a Menters SST, SA turbulence model in CFD++ commertial package. The results I am getting is not matching with the literature (DOI: 10.2514/6.2015-4220
) data. I am following same specification as given in literature but results are not matching. I am attaching my result with this post. Is anybody know, what can be the possible error ? please suggest |
January 1, 2018, 18:40 |
I do not see anything wrong with it. CFD is like this. In fact, I would be very surprised if your solution matches the other perfectly. Nevertheless, I can suggest you comparing the discretization technique used for both computations as well as the method used.
I guess you follow the procedure to obtain a grid independent solution. Try to check the numerical approach used for your case and the reference. |
January 2, 2018, 07:40 |
Bal Krishan
Rep Power: 9 |
Thanks juliom , I will follow through your suggestions
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 01:30 |
Two-phase critical flow and shock modelling of nozzle | Jeggi | STAR-CCM+ | 0 | December 4, 2014 10:12 |
Wind Tunnel Flow Simulation Mass Flow BC Issue | ledelman | SU2 | 4 | August 3, 2014 19:38 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 17:06 |
Turbulence Intensity Vs CFD Simulation | Apple L S Chan | Main CFD Forum | 3 | December 15, 1998 18:28 |
