TVD schemes on non-unform grids
Like Tree3Likes
  • 3 Post By mprinkey
Old   December 28, 2017, 11:29
Default TVD schemes on non-unform grids
AliE is on a distinguished road
Today I have a question for you regarding TVD schemes on non-uniform meshes.
Starting from the uniform case, we know that the face value of a general variable can be recovered using the following formula:
\phi_f = \phi_C +0.5*\psi(r)*(\phi_D-\phi_C)
where:
D= downwind node
C= upwind node
U = second upwind node
r= (\phi_C-\phi_U)/(\phi_D-\phi_C)
\psi= flux limiter
So if the limiter is zero then we have upwind, while if the limite is 1 we have a central difference scheme. Great!
If the grid is non-uniform, \psi=1 does not mean CDS, this is because the 1/2 in front of the limiter should be substituted by the classical interpolation weight factor \lambda=(xf-x_D)/(x_C-x_D) and this adjusts the things.
Now here comes my question:
consider the Van Leer flux limiter (at least what i have found around the web):
(\psi=(r+|r|)/(1+|r|)
its limit for r to infty is 2. However, for a non-uniform mesh we have:
\phi_f = \phi_C +\lambda*\psi(\phi_D-\phi_C),
and so the downwind scheme is not recovered in the limit case of very large r as should be...
Can somebody shed light on this behaviour? Maybe the limiter expression holds only for uniform grids?
Thank you very much,
AliE
AliE is offline   Reply With Quote
Old   December 28, 2017, 17:29
Michael Prinkey
mprinkey will become famous soon enough
In my experience, most discussion of limiters on unevenly (and even unstructured) methods are better considered in the context of gradient limiters. I'd refer you to the seminal paper on the subject, Barth, T. and Jespersen, D., “The design and application of upwind schemes on unstructured meshes,” AIAA-89-0366, 1989.But, IMO Marsha Berger does a better overview of the topic in a semi-review paper here:
https://www.nas.nasa.gov/assets/pdf/...nas-05-007.pdf
It does a nice job of bridging the gap and justifying the rationale of gradient limiting versus the canonical explicit forms used for evenly spaces methods.
Good luck.
FMDenaro, selig5576 and Brandon233 like this.
mprinkey is offline   Reply With Quote
limiters, tvd
TVD schemes, questions about limitedLinear davibarreira OpenFOAM 31 October 21, 2021 00:05
boundedness of TVD in 3D unstructured grids Lydia OpenFOAM Programming & Development 4 July 9, 2014 17:31
TVD schemes Vino Main CFD Forum 3 September 16, 2013 20:47
TVD schemes: 2 questions Shuo Main CFD Forum 0 August 19, 2008 22:51
TVD Schemes Matt Umbel Main CFD Forum 1 January 25, 2000 05:21
