Field Data Structure (Grid Index)
Like Tree1Likes
  • 1 Post By mprinkey
Old   December 14, 2017, 08:53
Default Field Data Structure (Grid Index)
javad haqqani
maksjood is on a distinguished road
Hi. How is the data, for example velocity, stored in OpenFOAM? I mean in what manner of indexing? If a 3D model is run.
maksjood is offline   Reply With Quote
Old   December 14, 2017, 15:44
Michael Prinkey
mprinkey will become famous soon enough
The OpenFOAM forum can help you with the specifics, but it (along with all unstructured CFD codes) store velocity (and other field variables) in 1D arrays. For OpenFOAM (FVM), these represent the cell and/or face values. The cells (say) are not in any particular order. In fact, unless you explicitly reorder them, they will be in the same order that your meshing software stored them. Parallel partition and Reverse Cuthill-McKee can reorder/subdivide them for parallel computation and performance improvements.
But the key notion with unstructured CFD is that the index on your array *MEANS NOTHING* relative to cell's position. This is a hard concept for people used to 2D and 3D structured codes where (i+1,j) is the neighbor (i,j). You have to find your neighbors by a neighbor list. The high-level differential operators in OpenFOAM hide all of those neighbor access details from you. Note too that you will need to look up, say, cell centroid location using the same indexing scheme if you need that in your calculations.
maksjood likes this.
mprinkey is offline   Reply With Quote
indexing, openfoam
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
Obtain Geometry Data from a Grid File in CFX 10.0 ARJUN CFX 2 August 17, 2006 08:20
Standard data structure for AMR Takuya Tsuji Main CFD Forum 1 January 8, 2002 03:14
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
