Similarity between Symmetric Gauss-Seidel and ILU0 smoothing
Like Tree1Likes
  • 1 Post By arjun
Old   December 2, 2017, 08:02
Default Similarity between Symmetric Gauss-Seidel and ILU0 smoothing
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Dear all,
in the Fluent manual, more specifically at the end of this page:
https://www.sharcnet.ca/Software/Ans...lar_couple_amg
it is stated that their ILU0 smoother is basically written as their Symmetric Gauss-Seidel one, the only difference being how they compute the diagonal blocks.
Not a linear algebra expert here, but the only reference I found on this is in Saad, Iterative Methods for Sparse Linear Systems, pp. 294, but it seems to me that he also states that this is not possible in general, and only cites the case where the system matrix is penta-diagonal as suitable for this equivalence.
Is anyone aware of additional references on this and/or if the Fluent approach (whose matrix is clearly not pentadiagonal) is actually correct?
Not that implementing ILU0 separately would be such a great deal, but would be great if possible by only working on the diagonal.
Thanks
sbaffini is offline   Reply With Quote
Old   December 2, 2017, 08:12
sbaffini's Avatar
Paolo Lampitella
The book of Saad can be found here:
http://www-users.cs.umn.edu/~saad/It...Book_2ndEd.pdf
but the relative page is 308.
Old   December 2, 2017, 14:33
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Paolo, maybe you can check the references cited in the book of Peric & Ferziger...
FMDenaro is offline   Reply With Quote
Old   December 4, 2017, 06:02
sbaffini's Avatar
Paolo Lampitella
Unfortunately, I had no luck with the book of Ferziger...
Old   December 4, 2017, 06:18
maybe you should enlarge the field of research...I mean, the "smoother" idea is more related to the multigrid philosophy, maybe the book of Brandt can give you some help
Old   December 4, 2017, 06:43
sbaffini's Avatar
Paolo Lampitella
At the moment I'm actually investigating the preconditioning world (where ILU0 seems to have a more prominent role) starting from the review of Benzi on JCP (http://www.cs.ucsb.edu/~gilbert/cs21...condSurvey.pdf) and following the references therein.
However, it seems that the formula used by Fluent is ILU0 applied just to the diagonal of the matrix.
Old   December 4, 2017, 06:54
Checked also the references in the SPARSKIT2 of Saad?
Old   December 4, 2017, 07:09
sbaffini's Avatar
Paolo Lampitella
Finally found it in here:
http://www.netlib.org/templates/templates.pdf
That version is known as DILU, and now all makes more sense
Thanks
Old   December 4, 2017, 07:38
sbaffini's Avatar
Paolo Lampitella
BTW, it is also discussed in the recent book "The Finite Volume Method in Computational Fluid Dynamics" by Moukalled et al.
Old   December 4, 2017, 08:02
sbaffini's Avatar
Paolo Lampitella
For the sake of completeness, here it is another good reference:
https://www.google.it/url?sa=t&rct=j...NgWw49Li29Ngqt-
Old   December 9, 2017, 21:49
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Thanks
i wanted to point you to it but had only access to phone where i couldn't log in to make comment.
Anyway here is an additional information might be useful to you, when in parallel, during the construction of DILU diagonal if the off diagonal matrix elements are on another processor then they are ignored. (in Fluent's case)
What it means that adding more and and more processors and performance of Fluent's dilu will go down.
sbaffini likes this.
arjun is offline   Reply With Quote
Old   December 11, 2017, 08:14
sbaffini's Avatar
Paolo Lampitella
I was indeed hoping for your contribution
But I have a question: is it really necessary to neglect offdiagonal terms related to "cells" on other processors? I mean, they actually are available. Is it a consistency reason (in the sense that they are not within the square block related to a given processor)?
Would the same apply also for ILU0? Or, maybe, would you do the same if you had to use the same reasoning for ILU0?
Thanks
Old   December 11, 2017, 13:02
Arjun
Thanks
The issue is that ILU0 or DILU factorization loop is serial so what they do is that they run it on each processor disregarding other processors. (as if that processor doesn't know of others).
(The issue is for Aij element of matrix we need also Aji element, this is not available. But if you know that matrix is symmetric then you can add this contribution. You can have such switch in your code).
It is not necessary and there might be a parallel way to do factorization too (i searched but i did not find). But shall be less efficient to construct.
Old   December 11, 2017, 14:12
sbaffini's Avatar
Paolo Lampitella
Ok, now I see it... I was only considering Aij with j out of processor (and not Aji). Thanks
