Choosing the right boundary condition
Like Tree1Likes
  • 1 Post By BlnPhoenix
Old   November 18, 2017, 23:52
Default Choosing the right boundary condition
Ghifari Adam Faza
fazaghifari is on a distinguished road
Hello
So I have this unresolved problem since a few weeks ago. I want to trap a water inside a cylinder domain with density profile and buoyancy model. The BC at the bottom of the cylinder is free-slip wall since I don't want the water going down because of the gravity. The BC at the top is opening BC with opening pressure 0 Pa. And the BC at the side is opening BC with opening pressure 0 Pa since I want to allow the water coming in and out.
And here's the problem. When I look at the result, the water is coming out of the domain from the side because of gravity.
So, what should I do to make the water is trapped inside of the domain, but the boundary is allowing the flow to come in and out?
Well, actually I can impose an opening BC with velocity U, V, W with 0 m/s. But it doesn't allow the water to come in and out.
note: I use Ansys CFX on this model.
Thanks,
Best regards,
fazaghifari is offline   Reply With Quote
Old   November 20, 2017, 04:47
BlnPhoenix is on a distinguished road
This doesn't make much sense. You either want the water to be contained in your container, or you want it to leave.
Can you perhaps describe what you want to model, so one can try to help to get this straight.
sbaffini likes this.
BlnPhoenix is offline   Reply With Quote
Old   November 20, 2017, 05:45
Ghifari Adam Faza
Actually, I just want to model a part of the bottom of a lake or sea.
Old   November 21, 2017, 05:23
Hmm, interesting. I'm not sure how you can do this actually. Can you model the whole lake very coarse and refine it locally where you need it? Very interesting problem..
Old   November 21, 2017, 05:30
Ghifari Adam Faza
So, I cannot only model the domain that I need? I mean although I have a very coarse mesh, it will be very big because the lake area is about 10 km^2 .
Old   November 21, 2017, 05:37
I don't see how at the moment. Has your lake special boundary conditions or is it just standing still all the time?
Maybe you can have inlet on one side and outlet on the other, that would mean that there is constant flow from one direction to the other though..
Old   November 21, 2017, 06:26
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Maybe you can adopt periodic BC.s as we did here https://www.researchgate.net/publica...blicationTitle
FMDenaro is offline   Reply With Quote
Old   November 21, 2017, 06:44
ehsan
e_cfd is on a distinguished road
Hello
Thanks,
Best regards,
You might use pressure outlet BC (in fluent ) and write a udf for the static pressure for the side boundaries (changing with the depth).
e_cfd is offline   Reply With Quote
Old   November 21, 2017, 21:53
Ghifari Adam Faza
Thank You
ansys, boundary condition, cfx
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Radiation interface hinca CFX 15 January 26, 2014 18:11
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
