Is there a simple way to avoid carbuncles for FD WENO methods?
Like Tree2Likes
  • 1 Post By praveen
  • 1 Post By Strat1994
Old   November 2, 2017, 13:16
Default Is there a simple way to avoid carbuncles for FD WENO methods?
Oleg Sutyrin
OlegSutyrin is on a distinguished road
I have implemented finite-difference WENO scheme for Euler equations (with some variants - WENO-JS, WENO-Z, WENO-M, different flux splitting). It works well, but have problem with so-called carbuncles (shock instability in the areas where its front is almost aligned with the grid). This problem seems to be well-studied for finite-volume methods (quick search shows that there are some fixes for Riemann solvers), but I can't find almost any information regarding carbuncles in finite-difference methods.
Are there any known fixes for finite-difference methods?
OlegSutyrin is offline   Reply With Quote
Old   November 2, 2017, 14:57
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I have no personal experience concerning the carbuncles problem. However, be careful on the fact that FD is a method based on the discretization of the differential form of the equations, a form that is not mathematically usable for simulating flows with discontinuities. For this reason you will find in literature the FV approach for such problems.
FMDenaro is offline   Reply With Quote
Old   November 2, 2017, 23:47
Praveen. C
praveen is on a distinguished road
Even though FD-WENO is an FD approach, it is still conservative and can be written as a finite volume method. You approximate flux derivatives by
\frac{\partial F}{\partial x}(x_i) = \frac{F_{i+1/2} - F_{i-1/2}}{h} + O(h^p)
where F_{i+1/2} comes from a WENO scheme.
FMDenaro likes this.
praveen is offline   Reply With Quote
Old   November 3, 2017, 04:15
Yes, I agree and I have to say that many times I found misleading the notations used in papers and books.
Often a FV approach is denoted as a discretization of the divergence form of the equations while FD is denoted the discretization of the quasi-linear form.
Actually, a real FV approach requires the definition of a volume for the integration of the divergence of the fluxes and is then defined by the flux reconstruction. For example, the book of Peric and Ferziger makes clear such distinction.
While considering the discretization for hyperbolic systems, where the solution can become singular, the notation that adopts the divergence form has a special meaning. It works no longer on the pointwise functions but on the volume-averaged functions (as explained in the book of Leveque).
For this reason a WENO reconstruction is suitable for solution with singularity.
Old   November 5, 2017, 08:07
Oleg Sutyrin
It seems that correct flux splitting is very important. I was using 3 versions (global and local Lax-Friedrich's and Roe-LLF) and was constructing flux splitting after weno-reconstruction of U and F(U) in local characteristic field. Now I weno-reconstruct already splitted flux. There are no more large-scaled carbuncles, but still are some weak shock front instabilities, so the question still stands.
Best results so far are obtained by proper Roe-LLF splitting with Roe averaging of Jacobians at x_j+1/2.
Old   November 8, 2017, 01:07
A, Smith
Strat1994 is on a distinguished road
Here are a list of a few papers that address this problem. The "H"-correction can be applied to any of the flux splitting methods you've implemented.
Yu-Xin Ren, Maio’er Liu, and Hanxin Zhang. A characteristic-wise hybrid compact-WENO scheme for solving hyperbolic conservation laws. J. Comput. Phys., 192:365–386, 2003. doi:10.1016/j.jcp.2003.07.006.
Richard Sanders, Eric Morano, and Marie-Claude Druguet. Multidimensional dissipation for upwind schemes: stability and applications to gas dynamics. J. Comput. Phys., 145(2):511–537, 1998. URL: http://www.sciencedirect.com/science...21999198960478, doi:http://dx.doi.org/10.1006/jcph.1998.6047.
Maurizio Pandolfi and Domenic D’Ambrosio. Numerical instabilities in upwind methods: analysis and cures for the “Carbuncle” phenomenon. J. Comput. Phys., 166(2):271–301, 2001. doi:http://dx.doi.org/10.1006/jcph.2000.6652.
OlegSutyrin likes this.
Strat1994 is offline   Reply With Quote
Old   November 10, 2017, 07:47
AGN
arungovindneelan is on a distinguished road
So for all the paper that I went through uses additional or implicit numerical diffusion in the schemes to escape from carbuncles. I guess global Lax-Friedrich's scheme gives relatively less carbuncle than others u have considered. This is because it adds more numerical diffusion by using max(|u+c|) over the domain as characteristic speed. U can slightly increase this value. It will diffuse the result, especially at contact adding too much will end up in bad result. Almost all the contact capturing or less dissipative schemes give carbuncles. Another way is, u can add more artificial diffusion like Jameson's artificial viscosity after flux calculation before WENO interpolation.
arungovindneelan is offline   Reply With Quote
Old   November 30, 2017, 06:20
Oleg Sutyrin
After quick testing, H-correction seems to solve the problem! It removes both large-scale carbuncles and small-scale nearly-grid-aligned-shock instability.
The first 2 papers linked by Strat1994 are very useful for implementation.
How to change the settings for FFD methods, please? Xiaosong SU2 3 September 7, 2019 07:13
Memory requirement for lattice boltzmann methods (simple BGK) amaal Hardware 0 January 18, 2011 12:14
Velocity Under-relaxation in SIMPLE type methods Matt U. Main CFD Forum 6 July 4, 2005 06:29
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 19:28
SIMPLE, SIMPLER, Vorticity-Stream Methods Compared Maciej Matyka Main CFD Forum 1 June 17, 2003 06:48
