September 6, 2017, 12:45 |
Total Pressure Drop at inlet and outlet
Rep Power: 14 |
Hi All
I have a basic question concerning the Total pressure at the inlet and outlet of a pipe with a divergent nozzle. I have 1.5 m/s as velocity and 3 bar as Inlet condition and at the outlet I am giving atmospheric condition. (1 bar atm) I have no slip BC condition for my walls and its iso thermal, single phase , internal flows. In my simulation i have some reverse flow but I am totally neglecting it. Now the doubt is according to the Bernoulli Principle my Total pressure at the inlet and outlet should be same. But its not the case. I have a total pressure of 3.15 bar at inlet and outlet is very less. But if I see my Pressure drop it is 2 bar (3 bar - 1 bar at outlet) So what could be this losses ? And why ? Kindly let me know regarding this issue. Thanks in advance |
September 6, 2017, 13:42 |
Rep Power: 19 |
From your description it sounds like you are running a viscous simulation. If this is true, then the total pressure will not be the same. Viscous losses show up as a loss in total pressure.
September 6, 2017, 13:45 |
Uwe Pilz
Rep Power: 15 |
Your B.C. is over-determined. Set you inflow velocity and set the outflow pressure to a reference value. The calculated inflow pressure reflects the dynamic pressure contribution then.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
September 6, 2017, 18:11 |
Filippo Maria Denaro
Rep Power: 73 |
Definitely, the total pressure is constant only for homoentropic flows. Viscous flows produce a loss in the pressure
September 7, 2017, 09:07 |
Rep Power: 14 |
I am using water as medium inside the channel. And hence the viscous effects are very less.
September 7, 2017, 09:11 |
Rep Power: 73 |
September 7, 2017, 09:43 |
Rep Power: 14 |
I am using inlet Velocity and outlet atm pressure. But in my experiment I am giving 3 bar at inlet and outlet 1 bar so In the post process I am looking at the pressure drop of 2 bar.
So to verify my results as I have reverse flow in my computation which I am not able to get away with. And I wanted to cross compare the results I check the Total Pressure at the inlet and outlet (I have high velocity at the difuser region, and high turbulence) And I see that there is a huge difference in the total pressure which means some kind of loss is there and what could be this loss ? Is there any special loss for friction due to turbulence and I read somewhere that there is some formula for loss due to turbulence. Then my velocity Magnitude will also be wrong right ? So I am thinking how to validate those results ? |
September 7, 2017, 09:44 |
Rep Power: 14 |
But then the loss shouldnt be too much right ?
September 7, 2017, 15:08 |
#9 |
Rep Power: 19 |
The amount of head loss is going to depend on velocity, length of pipe, pipe roughness, and turbulence, along with minor factors such as expansions and contractions. Assuming your flow is fully developed you can do a reasonable approximation using the 1D energy equation (which looks like the Bernoulli equation with the head loss added), and a Moody diagram to determine your friction factor. If your flow is not fully developed then you would need to follow a more involved process. But the head loss (or loss of total pressure) may or may not be significant.
September 8, 2017, 04:47 |
#10 |
Rep Power: 14 |
Perfect Thanks a lot. I will have a look into it.
September 8, 2017, 04:54 |
#11 |
Arjun Kalkur
Rep Power: 9 |
You can calculate the losses due to turbulence using Darcy Equation. And yes, since you just want to define the inlet pressure, I'd suggest you to use boundary condition as pressure- inlet instead of velocity. The pipe length also leads to pressure losses, in the case of a divergent duct, as the pipe length increase, there might be losses at some point due to flow separation.
Hope it helped. |
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet | coolcrasher | OpenFOAM Post-Processing | 7 | November 4, 2021 04:57 |
Pressure inlet vs outlet position, transient, time dependent pressure and gravity | silent2608 | FLUENT | 0 | February 6, 2016 10:19 |
Pressure Inlet: question about total pressure | I-mech | FLUENT | 0 | July 13, 2014 05:38 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
