System Hardware Requirements for 3D Multiphase FLows. |
August 23, 2017, 01:49 |
Lolita
Rep Power: 10 |
Hello friends
I want to buy a system to perform simulations on 3D Multiphase flows, and i want to know the system requirements so that, i am able to perform all the simulations without any difficulty and less time. Thanks |
August 23, 2017, 09:26 |
#2 | |
Alex
Rep Power: 49 |
Rather a question for the hardware subsection of the forum.
However, you will have to provide more details in order to get a useful answer. Quote:
August 23, 2017, 09:34 |
Rep Power: 14 |
For 3D multiphase simulations i usually recommend buying a Supercomputer.
August 23, 2017, 12:54 |
Alex
Rep Power: 49 |
That's certainly one possible solution if you want to play it safe
August 23, 2017, 13:42 |
Ezequiel Krumrick
Rep Power: 12 |
In my case, I am doing some RANS simulations in 2D and 3D, more or less 2 million cells. I use an Intel Xeon E3 V3 server with 32 GB RAM. This works fine for me. Regards, Sent from my XT890 using CFD Online Forum mobile app
Best regards, Ezequiel |
August 24, 2017, 02:55 |
Lolita
Rep Power: 10 |
August 24, 2017, 18:15 |
Rep Power: 17 |
This really depends on what multiphase model you want to solve. Total number of dof will give you an idea of the RAM you need. Total dof depends on the mesh size but also on the total number of equations (number of phases and number of equations per phase), discretization type (first order FV is not the same as high order DG, explicit euler time stepping is not the same as high order RGK or implicit), etc. My working computer is based on a T7910, 16 3-years old cores and 64gb RAM memory. In terms of RAM memory I can solve more than 10 million elements for a 7 phase 5-equation/phase model with explicit time stepping. In terms of CPU time, though it is a whole different story... and honestly I am not that patient and run these simulations on a cluster. To make it short, it is easy and rather cheap to design a desktop computer that will run your case. Evaluating computing time is not easy at all without more details. |
hardware requirements for 31m cell case | petrile_83 | Hardware | 3 | October 22, 2011 22:55 |
multiphase flows | Allen Badeau | Main CFD Forum | 6 | February 6, 2003 09:38 |
Multiphase flows with combustion | Pawel Kosinski | Main CFD Forum | 5 | March 9, 2000 13:07 |
Multiphase Flows | Elliot Schwartz | Main CFD Forum | 6 | May 28, 1999 03:11 |
CFD for multiphase flows? | David Strutt | Main CFD Forum | 12 | October 19, 1998 05:56 |
