Induced downwash velocity for drag computation in Vortex Lattice Method (VLM)
Like Tree1Likes
  • 1 Post By Sehwan
Old   August 9, 2017, 04:51
Default Induced downwash velocity for drag computation in Vortex Lattice Method (VLM)
Se Hwan Park
Sehwan is on a distinguished road
According to Low-Speed Aerodynamics by Katz and Plotkin, the downwash induced by the wing's streamwise vortex lines and the wake is used for computing the induced drag in Vortex Lattice Method.
Here, I cannot understand the reason why only the trailing (streamwise) segments of the wing-bound vortices are considered in obtaining the downwash for induced drag calculation while the spanwise segments of the wing-bound vortices are neglected.
In the VLM source codes, to satisfy a boundary condition at collocation points, an influence coefficient matrix is established by computing the induced velocity by the wing-bound vortices (streamwise and spanwise segments of the wing vortex rings).
During the phase of the influence coefficient computation using the same subroutine, the another influence matrix can be established by computing the normal velocity component induced by the streamwise segments of the wing vortex rings with influence of the spanwise vortex segements turned off. This is used for induced drag computation.
I've been following this procedure, and the prediction was accurate. However, I would like to know the reason why the spanwise bound vortices' influence is not considered in downwash compuation for the induced drag.
Sehwan is offline   Reply With Quote
Old   August 9, 2017, 07:00
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
If you look the neglected part, which is span aligned, you can see that it is a 2D like component which doesn't produce drag. I quote: "while the drag force, which is created by turning the two-dimensional lift vector by the wake-induced flow, becomes:", Katz&Plotkin, pp.173.
Put differently, is the spanwise variation of the circulation which is responsible for the induced drag.
Put still differently (see equation 8.12), it is the wake induced angle which modify the free stream angle of attack to produce the effective angle of attack.
sbaffini is offline   Reply With Quote
Old   August 13, 2017, 23:21
Se Hwan Park
Thank you for your reply, Mr. Lampitella.
Now I got it.
sbaffini likes this.
Old   September 13, 2018, 15:33
Default issues with Katz method
Zack
ZakBristol is on a distinguished road
I have tried using the trailing vortex to calculate induced velocity in VLM. However, that gave an incorrect solution.
What is the correct way of calculation induced velocity and angle of attack using VLm for any given camber,
Thanks
ZakBristol is offline   Reply With Quote
downwash, induced drag, streamwise vortex, trailing vortex, vortex lattice method
Linear-Strength Vortex Unsteady Panel Method (2D) Sonik_87 Main CFD Forum 18 February 23, 2020 10:16
Presenation of vortex strength and velocity concept? fruitkiwi Main CFD Forum 0 September 26, 2012 23:08
Calculating Velocity from a VLM method jd88 Main CFD Forum 0 September 9, 2010 17:24
is there any method give node based velocity BC? daniel FLUENT 2 July 18, 2006 22:21
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
