August 2, 2017, 12:05 |
Dual Time Stepping
Tom-Robin Teschner
Rep Power: 17 |
I have some issues implementing the dual time stepping procedure and was hoping some experienced eyes can help me out. Suppose I want to solve the advection equation using a dual time stepping procedure, then I have
, where and are the pseudo and real time, respectively. Using first order (for simplicity) for all the derivatives, I get . I define the right-hand side (RHS) as and then can rewrite the equation in explicit time integration form as . Once , where is some small (convergence number), the pseudo time derivative vanishes and i obtain the solution at the next time step. The pseudo code for my example follows below Code:
while() while( and ) Do i=2 to n End Do i=2 to n End calculate residual set iteration=iteration+1 End End Last edited by t.teschner; August 3, 2017 at 15:13. |
August 2, 2017, 17:41 |
Filippo Maria Denaro
Rep Power: 73 |
I never worked with such a procedure, thus I have no experience about the advantage in doing that. However, I see that for dt=dtau you get the increment without
u^{n+1,m} so I wonder what about the iteration over m... |
August 3, 2017, 05:40 |
Tom-Robin Teschner
Rep Power: 17 |
well, as far as i understand, the method was introduced to allow usage of fast time marching algorithms (implicit schemes, multigrid etc.) which need not to be accurate but give a steady state solution fast. the time accurate solution is recovered with the second timestep which can follow its on stability criterion.
well, so far the theory, but all method derived from the artificial compressibility method in incompressible flows (which i am working on) suffer from the inherent pseudo time marching so the only way, really, to get an unsteady simulation, is to use the dual time stepping procedure. so i though i start with a simple advection equation but yeah, if than vanishes. I suspect the problem to be somewhere in the update of the variables, though. |
August 3, 2017, 10:44 |
The DTS formulation refers to the fact that you have 2 time derivative terms, one of which is in pseudo-time, the other in actual time so, formally, by construction, it is used for unsteady computations. By extension, it is also possible for steady states, where the true time derivative term is assumed to be 0.
Now, what the problem is for such unsteady computations? That the explicit stability limit to advance them might require much lower time steps than accuracy would, possibly only because of few problematic cells. The idea of the DTS is thus to introduce a pseudo-time derivative, discretized with a local time step (on a per cell basis) based on the local stability limit, and use such pseudo-time to advance explicilty the solution until it doesn't change anymore in pseudo-time, which means that the pseudo-time derivative has disappeared and the remaining terms (i.e., the original equation) are fully balanced. Now, what should be clear is that, really, it only makes sense for implicit discretizations in time or implicit steady states. Otherwise, your physical time step, by construction, has to be, for each cell, equal to the lowest allowed pseudo-time step in the grid. So, to start with, as your discretization is explicit, both in time and pseudo-time, both time steps have to respect the stability limits. For your simple case it means: Do the both of them respect these constraints? Second question, how do you determine convergence within pseudo-time? Are you sure you are not simply using all the allowed iterations without actually converging? (Also note that, typically, the condition used in the check is an AND, not an OR) |
August 3, 2017, 15:37 |
Tom-Robin Teschner
Rep Power: 17 |
thanks for spotting that, in my code i have indeed a "and" statement, not or. and yes, i specify the timestep according to the stability criterion stated in your post. as i was saying before, when dealing with the artificial compressibility method, dual time stepping is the only way to achieve unsteady simulations, so we don't use it for the larger timestep reason as in compressible flow and hence an explicit method will work just fine for me.
i set my maximum iterations to 100 and found convergence for eps=1e-8 to be around 30 iterations, i played around with the maximum iteration number and eps but usually the solution converged in pseudo time before the maximum iteration count was achieved. the residual is calculated based on the L0 norm and i just take the maximum difference of u between m+1 and m (and normalise that difference so that the residual is 1 at the first iteration). if it helps, i put the matlab code below (i use k here instead of m to indicate the pseudo time level) Code:
%% the program solves the advection equation with dual-time stepping clc; clear; close all; %% initial parameters % problem specific parameters a = 1.0; % wave speed n = 1001; % number of elements in x CFL_r = 0.8; % CFL, real time CFL_p = 0.4; % CFL, pseudo time t_end = 5.0; % compute until % convergence criterion in pseudo time eps = 1e-8; % convergence parameter in pseudo time imax = 100; % maximum iterations in pseudo time % calculated parameters dx = 20/(n-1); % spacing dt_p = CFL_p*dx/a; % delta t(au), pseudo time dt_r = CFL_r*dx/a; % delta t, real time % solution arrays un1k1 = zeros(n,1); % u^{n+1,k+1} un1k = zeros(n,1); % u^{n+1,k} un = zeros(n,1); % u^{n} unm1 = zeros(n,1); % u^{n-1} uana = zeros(n,1); % u analytic RHS = zeros(n,1); % right-hand side vector % space vector x = linspace(-10,10,n); % x vector % initialise solution for i=1:n un1k1(i) = 0.5*exp(-x(i)^2); un1k(i) = 0.5*exp(-x(i)^2); un(i) = 0.5*exp(-x(i)^2); unm1(i) = 0.5*exp(-x(i)^2); end % compute analytic solution for comparison for i=1:n uana(i) = 0.5*exp(-(x(i)-t_end)^2); end %% time loop % loop in real time (outer loop) t_r = 0.0; while(t_r<t_end) % copy values unm1 = un; un = un1k; % loop in pseudo time (inner loop) res = 1.0; iter = 1; while(eps<res && iter<imax) % copy values un1k = un1k1; % loop over space for i=2:n % assemble right-hand side temp = getRHS(un1k, un, unm1, dt_r, dx, a, i); RHS(i) = temp; end % time integration in pseudo time for i=2:n un1k1(i) = un1k(i)+dt_p*RHS(i); end % calculate residual res = abs(max(un1k1-un1k)); if (iter == 1) if (res ~= 0.0) resnorm = res; else resnorm = 1.0; end end % normalise residuals res = res/resnorm; % print to screen if(mod(iter,100) == 0) fprintf(' iter: %d residual: %12.5e\n', iter, res) end % increase iteration counter iter = iter + 1; end fprintf('time: %12.2e iterations in pseudo time: %d\n',t_r,iter); t_r = t_r + dt_r; end %% plot solution plot (x,un1k1,x,uana) legend('numerical','analytical','location','northwest') ylim([0 0.5]) Code:
function [temp] = getRHS(un1k, un, unm1, dt_r, dx, a, i) temp = (-1.0)*(3*un1k(i)-4*un(i)+unm1(i))/dt_r - a*(un(i)-un(i-1))/dx; end |
August 4, 2017, 01:57 |
I can'try your code now. But I suspect that the following 3 points are creating troubles:
1) res = abs(max(..., where it should be max(abs(... 2) you are not using the 1st order explicit euler in real time as claimed, but a 2nd order backward discretization. Still, you have it wrong, because you need to divide that by 2dt 3) as per point 2 above, your discretized physical unsteady term is actually defined at n+1, which means you would need to go implicit. I don't know if staying explicit here just means reverting to 1st order |
August 4, 2017, 03:37 |
Tom-Robin Teschner
Rep Power: 17 |
it was about point 2 ... thanks, problem is solved now (forgot to devide by 2dt). i just used first order in the opening post for simplicity but 2nd order in the code. and there does not seem to be a problem with having a double explicit scheme, as stated before, for artificial compressibility based methods its the only way to introduce real unsteady behaviour so both pseudo and real time can be explicit. in this case i just use the advection equation to simplify the problem. but thanks again for spotting the bug
dual time stepping |
Elastic or Plastic Deformations in OpenFOAM | NickolasPl | OpenFOAM Pre-Processing | 36 | September 23, 2023 09:22 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 23:40 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 08:56 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
