Viscosity in Standard Wall Function
Like Tree1Likes
  • 1 Post By dinhanh
Old   August 1, 2017, 05:45
Question Viscosity in Standard Wall Function
Anh
dinhanh is on a distinguished road
I am trying to write the standard wall function code for my study. I uses the standard k-epsilon model with Launder-Spalding wall function. I refered from the CFD-Online Wiki and from the report of J. Bredberg "On the Wall Boundary Condition for Turbulence Models".
The three steps is procedured at the first node away the wall, P
1. Modify wall viscosity.
2. Modify production and disipation terms in k equation.
3. Specify the value of epsilon.
I have done all step with the limitation for ystar (y*) as scabale wall function and run the simulation code. I checked the y* value that all are >30. However, the contour of turbulent kinetic energy and viscosity shown strange when those values become small at the wall and point P.
The modify viscosity in those references is;
nutt=cmu^.25*k^.5*y*kapa/ln(E*(y*))
I found from another reference that
nutt=kapa*cmu^.25*k^.5*y
But got the same result. I could not find the solution for this code. All the proceduces that I did are correct? If you could give the explaination or solution for my problem, please kindly help!
Thank in advance!
dinhanh is offline   Reply With Quote
Old   August 1, 2017, 06:37
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
I do not program my wall functions in this way, so I can't be of any help here. Still, OpenFOAM does it, you might have a look at how it does.
Check it under src/TurbulenceModels/turbulenceModels/derivedFvPatchFields/wallFunctions
nutWallFunctions should be what you're looking for. Still you might want to give a look around.
Unfortunately I can't give any more hints as I don't actively work on the OF source code.
sbaffini is offline   Reply With Quote
Old   August 1, 2017, 06:53
Anh
Thank you, Paolo Lampitella
I looked the OF source code. I think they do the same what I did. But my result show some what strange, I think. Also, my code is finite difference method. Anyway, Thank you for your help.
Old   August 1, 2017, 06:56
sbaffini's Avatar
Paolo Lampitella
May I suggest working on a simpler setting, where you can filter out any other possible influence? For example, you might work on the channel flow, where the equations would reduce to 1D only on half channel height.
Old   August 4, 2017, 04:12
Anh
Thank Paolo,
I found the problem. That caused by the minimum limitation I set for turbulent value.
My problem is cavitation modeling. However, the results is stll somewhat strange when the turbulent viscosity at wall is small
sbaffini likes this.
Standard Wall Function junz FLUENT 1 December 2, 2016 03:04
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
k-e standard wall function and y+ macfly FLUENT 0 March 3, 2010 17:28
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
