Calculating Cd of disk
Like Tree2Likes
  • 1 Post By rajnarayang
  • 1 Post By Lucas_Gasparino
Old   July 10, 2017, 18:07
Default Calculating Cd of disk
hitre is on a distinguished road
Hello. New here and also to CFD. I created symmetrical 3d geometry with cylindrical fluid domain and with half of disc inside. I'm trying to measure Cd with laminar flow. during calculation I got periodical residuals and also Cd. I tried with increasing boundary layers and thickness on the front side of disc but still it oscillates. What else can I do? I started calculation with Standard pressure equation and first order upwind momentum. Reference values are ok. But how can I improve mesh more?
hitre is offline   Reply With Quote
Old   July 10, 2017, 18:29
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
What about the Re number? depending on the value you can get laminar but oscillating solution.
FMDenaro is offline   Reply With Quote
Old   July 10, 2017, 18:31
I have specified RE values to observe CD
Old   July 10, 2017, 18:35
Is the solution steady for Re<10?
Old   July 11, 2017, 04:33
yep solution is converged. But i have experimental data with the lowest value of Re = 100. (i need to compare with experimental data)
Old   July 11, 2017, 04:38
I strongly suspect that at Re=100 you do not have a physical steady solution
Old   July 11, 2017, 05:03
rajnarayang's Avatar
Raj Narayan.G
rajnarayang is on a distinguished road
What is the Re for the case that is giving you oscillating solution??
Sent from my Nexus 5 using CFD Online Forum mobile app
rajnarayang is offline   Reply With Quote
Old   July 11, 2017, 05:06
Raj Narayan.G
Prof. Denaro,
Why did you specifically ask if Re below 10? Is Re<10 some how critical??
Old   July 11, 2017, 05:07
I can only assume that the flow around a bluff body is steady for Re=O(1)
Old   July 11, 2017, 05:09
I used Re around 400
Old   July 11, 2017, 05:10
Raj Narayan.G
The critical Re for von Karman vortex street is close to 300. Hence, wouldn't it be safe to assume that the flow around any bluff body is "steady" till that Re value?
Old   July 11, 2017, 05:13
Raj Narayan.G
Critical Re for von Karman vortex street is close to 300 (as seen in An Album of fluid motion). Your Re maybe in the transition domain.
yutingj likes this.
Old   July 11, 2017, 05:17
Raj Narayan.G
A snapshot from the book
Old   July 11, 2017, 05:39
Cylinder is not a bluff body
Old   July 11, 2017, 05:40
I just played around (wasnt aware about critical reynolds at that time) and reduce Reynolds on 100. It's ok. So the problem obviously was that I without knowing random hit critical Re number
Old   July 12, 2017, 07:34
Lucas Gasparino
Lucas_Gasparino is on a distinguished road
At certain Re, the stabilized solution really is periodical (I'm assuming your run is transient, otherwise the calculation residuals do not converge well). What you can do is time average the Cd solution, which will give you something very close to experimental data, itself a time average of the experiment. Also, if the solution is periodic, I'd recommend using a full model. Try making the mesh as structures as possible close to the body, and do some refinement studies to evaluate mesh independence. Do you have any reference to base your results?
Sent from my XT1635-02 using CFD Online Forum mobile app
FMDenaro likes this.
Lucas_Gasparino is offline   Reply With Quote
Questions on dynamicTopoFvMesh danvica OpenFOAM Running, Solving & CFD 80 April 16, 2019 17:58
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
Virtual Disk Model-Report afarkas STAR-CCM+ 2 July 7, 2017 06:29
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
