June 15, 2017, 12:06 |
Load Balancing Algorithm
Kris
I'm doing some undergrad research this summer and am tasked with writing a load balancing algorithm for an existing code. I will be writing in Fortran90. I have been doing a ton of research and reading and am having a hard time coming up with a template for what a simple load balancing program looks like. I know the basic principles and the process but I feel that I would gain a more intimate understanding of what I need to be doing and what kind of problems I might encounter if I could write a simplified example for myself. I was thinking of something like intentionally unbalancing a 1-D conduction problem and then writing a balancing algorithm from there. Any suggestions? Anyone know of any existing resources I may have not found yet? If it helps, the existing code simulates multiphase flow in a structured grid. I don't find a lot of literature on balancing structured grids but I feel like if I can even get a basic balancing scheme written I can start to apply concepts to our actual problem. Thanks so much.
June 15, 2017, 13:42 |
Arjun
Rep Power: 35 |
If you send me your email in pm i will send you at least one example code to get things started.
June 15, 2017, 13:57 |
Arjun
Rep Power: 35 |
Sent you mail.
Run-Time Parallel Load Balancing | tgvosk | OpenFOAM Programming & Development | 25 | December 4, 2024 04:51 |
[Other] Load balancing with dynamic mesh | tikulju | OpenFOAM Meshing & Mesh Conversion | 12 | May 26, 2017 00:04 |
Dymanic load balancing in dynamicRefineFvMesh | Aleksey_R | OpenFOAM Programming & Development | 3 | January 29, 2016 18:29 |
load balancing in parallel computation | shyamdsundar | Main CFD Forum | 0 | September 3, 2009 00:53 |
Hanging node grid + load balancing in parallel??? | Phil | FLUENT | 0 | February 15, 2008 09:38 |
