Aru
Rep Power: 14 ![]() |
I am computing energy spectrum for computationally obtained turbulence data, which is statistically homogeneous in 2 directions (X & Z). The energy spectrum is calculated for a homogeneous plane, using Fourier transforms of the spatial data.
![]() The calculated spectrum shows a 'bump' at higher wavenumbers (not the highest). It is prominent in a semilog plot (attached). I am wondering what could have resulted in this anomalous behaviour. I assume it is associated with some error in calculating the spectrum but has nothing to do with the physics. However, I am unable to find any error in the calculation. I would like to know if anybody in the community has encountered a similar erroneous spectrum, and what could cause such anomaly? |
Uwe Pilz
Rep Power: 15 ![]() |
You may look whether the wavelength of your bump region coincides with the size of the mesh.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Aru
Hi piu58,
I should have mentioned my mesh and domain earlier. ![]() There are 512x128 points in the XZ plane which has a physical dimension ![]() ![]() ![]() ![]() ![]() ![]() I understand that under-resolved data results in oscillations at highest wavenumbers.In this case, I am perplexed by the smooth spectrum beyond ![]() |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
What problem are you solving, a plane channel flow? And what about the Re_tau of your problem? what about y+ of the computed spectrum?
What I do not understand is the fact you have the spectrum extending over the Nyquist frequency... Or am I wrong in understanding your comment? Then, the magnitude of E(k) is very high, why? |
Aru
The problem under consideration is temporal mixing layer.
On the x-axis I have ![]() ![]() As of now, both k and E(k) are not scaled. My objective of plotting the spectrum is to make sure I am resolving the scales sufficiently. |
#7 | ||
Aru
To summarise, can I attribute the "bump" to the method where I am going above the Nyquist limit? |
Compute the 1d spectra but perform the spatial averaging along the normal direction
#9 | |
Aru
#10 | |
No, you compute first the FFT and then you perform the average of the coefficients |
#11 |
Aru
The calculated one-dimensional spectrum is attached.
A smooth curve is not obtained even after averaging FFT coefficients in the Z direction. Is it required to perform an average in time to obtain a smooth spectrum? |
#12 |
That looks quite correct ... have a look at sec.5.2 here
https://www.researchgate.net/publica...-uniform_grids and Ref.42 in the reference |
#13 |
Aru
One dimensional spectra,
![]() ![]() In this reference, the spectrum is calculated as ![]() which seems to be an averaging in the non-homogeneous direction. If so, what difference this makes to the spectrum? |
#14 |
Your results seems physically acceptable.
You can have two choices: 1) the averaging along the non-homogeneous domain give the total energy content of the mixing layer for each wavenumber component. 2) computing and analysing spectra at several stations along y+. This is for example the standard procedure for a channel flow. Both are correct and the choice depends on what you want to analyse. I used the averaging along y to compare the solutions with the paper of Lesieur. |
#15 | ||
Aru
Dear FMDenaro,
Thank you for your valuable suggestions. Can you provide some clarification regarding the 'binning' procedure? Quote:
#16 |
The plot is versus the frequency or the integer wavenumber, the relation being k=n*2*pi/L (n=0,1,2..,Nmax). The Nyquist frequency is kmax=pi/h. This is for each direction Lx and Lz.
What do you mean exactly for "binning procedure"? |
#17 |
Aru
The length of the domain in x direction is
![]() In the latter plot, I have used only integer values of wavenumber on the x-axis. The energy of non-integer wavenumbers is rounded off to nearest integer k. For example, E(1) is the sum of all u(k)^2 for k=4/8,5/8,.....,10/8,11/8. This procedure was described in a reference, but I couldn't trace it now. |
#18 |
After you perform the FFT, you have a vector of the complex Fourier coefficients for each integer n=0,1,... Thus, you can plot (in a log scale) the modulus versus these non-dimensional numbers or you simply convert the integers in the dimensional spatial frequency k = n*2*pi/L.
No "binning" in such procedure... |
How can I map the spectrum energy with its associated velocity field? | juliom | Main CFD Forum | 0 | March 23, 2016 08:16 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
turbulent energy spectrum | cfd.newbie | Siemens | 1 | June 19, 2008 23:48 |
LES correlation and turbulent energy spectrum | Fabian | Main CFD Forum | 4 | October 18, 2005 02:04 |
Energy Spectrum | Emad Khalifa | Main CFD Forum | 3 | June 30, 2003 16:03 |
