May 18, 2017, 20:47 |
Definition of the variable uvw?
David
Rep Power: 9 |
I am quite new to CFD and my question here may be a bit easy for you. But I am really struggling and your help are really appreciated.
I have came across a variable uvw which I really can't find a definition to it. I know that uv represents Reynolds stress, but not uvw at all. Also, can someone briefly describe what is our purpose of calculating the root mean square of a variable, like streamwise velocity fluctuation? Thank you in advance for your kind help. |
May 19, 2017, 01:05 |
Svetlana Tkachenko
Rep Power: 15 |
Regarding the last question, mean of a fluctuation is zero, so mean of its square is used instead. This allows to quantify the magnitude of the fluctuation.
May 19, 2017, 04:18 |
#3 | |
Filippo Maria Denaro
Rep Power: 73 |
May 19, 2017, 10:19 |
#6 | |
Rep Power: 73 |
For example, in turbulence modelling you could construct the evolution equation for the components of the Reynolds stress tensor. Thus, you could read that as the velocity component u transporting the variable (vw) in the convective flux |
May 22, 2017, 12:03 |
David
Rep Power: 9 |
Thank you very much FMDenaro.
root mean square, turbulence statistics |
Variable name for heat flux | peterle | CFX | 4 | February 13, 2014 03:21 |
Instalation on ubuntu 710 | basilwatson | OpenFOAM Installation | 17 | March 16, 2012 21:16 |
Additional Variable | tav98f | CFX | 3 | April 28, 2011 13:33 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
Question about making a variable function of proprities of onother variable ? | rafiktharwat | CFX | 0 | March 26, 2011 15:23 |
