Wall function for rotating or counter rotating wall
Like Tree2Likes
  • 1 Post By sbaffini
  • 1 Post By ferferimori
Old   May 4, 2017, 18:29
Default Wall function for rotating or counter rotating wall
ferferimori is on a distinguished road
I am looking for formulation of standard wall functions for rotating or counter rotating walls. Since we are skipping the wall, the rotational speed of the wall cannot be modeled directly, instead it has to be modeled through extra terms in the law of the wall expression. Does anybody know how can I found the rotating version of wall functions?
I searched through literature but most of the rotating walls use a rotating frame and since they are not modeling a counter rotating wall, there is no need to impose the rotation in wall functions explicitly. I found this paper by Rhode et al. but they do not explain how they come up with their formula:
http://tribology.asmedigitalcollecti...icleid=1460204
Does anybody know a better reference with more detailed explanation?
Thanks
ferferimori is offline   Reply With Quote
Old   May 5, 2017, 08:20
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
What do you mean? For a given cell center next to the wall, the normal-to-the-wall line passing trough this point is usually well defined and intersects the wall at a unique point. As you know the wall velocity at that point, you can always formulate the wall function problem in a reference frame moving at the velocity of that point. Why not?
ferferimori likes this.
sbaffini is offline   Reply With Quote
Old   May 9, 2017, 17:34
Thanks Paolo, You are right. One should extract all the velocities in the relative frame and use them for the wall function/wall shear expression. For other people who are looking for the same procedure they can refer to a dissertation at TAMU by Demko (Prediction of flow in labyrinth seals). I found his discussion adequate and helpful.
sbaffini likes this.
counter rotating wall, wall function
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Rotating region of a centr. pump - Counter R wall Emre CFX 0 September 20, 2007 10:58
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 05:05
