Oscillating behaviour of variables in a very fine grid
Like Tree1Likes
  • 1 Post By FMDenaro
Old   May 4, 2017, 11:56
Default Oscillating behaviour of variables in a very fine grid
Stuntmanbob is on a distinguished road
Hi guys,
i'm simulating the flow around an airfoil of a turbine and had to do a grid convergence study. Therefore i refine my mesh in TRACE, by multiplying the number of nodes in i,j,k-direction by two (finer mesh), and three (finest mesh). So the first mesh has about 2.1 million nodes, the second 16.3 million and the finest about 54.4 million nodes.
When i look at the distribution of the Cp-Value on the blade surface, the finest mesh shows an oscillating behaviour (Screenshot). And so all the other calculated variables, like density.
TRACE uses linear interpolation to set the new points. But the oscillating behaviour can't be seen in the results of the first two mesh, so i think that's not the problem.
Maybe it is a numerical problem? Anyone with ideas?
Thanks in advance and sorry for my bad english.
Greetings,
Stuntmanbob
Stuntmanbob is offline   Reply With Quote
Old   May 4, 2017, 12:04
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Are you working in double precision? check if the grid refinement over the airfoil is smooth
Stuntmanbob likes this.
FMDenaro is offline   Reply With Quote
Old   May 4, 2017, 13:40
you're right, the smoothness looks very bad. Thank you very much
Greetings,
Stuntmanbob
Residuals show oscillating behaviour ! anon_l STAR-CCM+ 1 October 30, 2016 15:38
Grid Check Script pdp.aero SU2 2 April 23, 2015 02:54
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
Algebraic Multigrid for nonuniform grid Joshua Lee Main CFD Forum 4 March 16, 2000 14:05
Non-uniform grid calculation Aspens Main CFD Forum 1 February 23, 2000 15:15
