Boundary layer thickness calculation for internal flow |
April 27, 2017, 17:19 |
Rep Power: 11 |
Hi all,
Could anyone advise or provide reference on how to calculate BL displacement/momentum thickness for internal flow (say inside an axi-symmetric curved duct)? In particular, I'm not sure how to choose the free stream velocity and density, as for internal flow the flow normally has some gradient along the span. Thanks! |
April 28, 2017, 00:01 |
Lucky
Rep Power: 66 |
From a fluids and turbulence standpoint, an internal flow is which in which boundary layers takes up the whole duct and there is no more a freestream velocity. Displacement and momentum thickness are not very meaningful here.
If BL does not take up the whole duct, then you have a developing BL and it acts like an external flow (with curvature) and only here do you have a freestream velocity. This freestream velocity has the same meaning as usual although the freestream velocity can accelerate/decelerate under an inviscid pressure gradient which you can calculate very easily by application of Bernoulli's equation for example. |
April 28, 2017, 05:13 |
#3 | |
Rep Power: 11 |
Hi LuckyTran,
Thanks for your reply. Given my duct is curved and the flow (pressure for instance) has spanwise variation as well, should I perform an inviscid CFD for the same geometry and extract V_freestream from the result? If so my follow up questions is how to calculate this freestream velocity then? Is it at the mid span? Quote:
April 28, 2017, 06:11 |
Filippo Maria Denaro
Rep Power: 73 |
No at all, it makes no sense an inviscid fluid model for your case...
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
boundary layer thickness for pipe flow | ranjith | CFX | 4 | September 13, 2015 23:29 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 14:47 |
