March 25, 2017, 02:16 |
Spalart-Allmaras Divergence Issue
Sree Vaibhav
Rep Power: 9 |
Greetings,
I'm trying to simulate the effectiveness of various turbulence models over RAE2822 airfoil at Transonic Speeds. I've used SKE,RKE,SKW,KWSST,TRKKLW and RSM. All of them have successfully simulated the flow while SA's nut(Turbulent Kinematic Viscosity) is diverging. Please give me your suggestions. Thank you. |
March 25, 2017, 06:27 |
The good thing is that is only one that is not converging. It means that your problem is well posed. Thus, I guess that your mesh and boundary conditions are also right. This is what I would do if I were you. Use the solution of any of the converged solution as initial condition and solve the problem in a transient approach. Sometimes, the only way to solve a problem is using transient approach. I'm sure it will work out.
March 25, 2017, 08:11 |
Well, while the suggestion from Julio is generally valid, my experience implementing 1 and 2 equations turbulence models is that SA usually is the only one you get right straight out of the box, but only if you closely follow the reference.
As all your other turbulence models are working, I assume you know how to properly handle positive and negative contributions of turbulence source terms to the matrix coefficients (i.e., how to only consider contributions which enhance stability), as well as all the other common features for such models. Then, if we exclude a specific implementation bug for SA (which only you can be aware of), this only leaves out one thing you might not be aware of about SA. That is how to properly implement its diffusion term; more specifically its non conservative part. How did you implement it? |
March 28, 2017, 00:44 |
#4 | |
Sree Vaibhav
Rep Power: 9 |
March 28, 2017, 00:45 |
#5 | |
Sree Vaibhav
Rep Power: 9 |
March 28, 2017, 04:00 |
#6 | |
March 28, 2017, 04:34 |
Sree Vaibhav
Rep Power: 9 |
Thank you for your input. Much appreciated
March 29, 2017, 12:13 |
#8 | |
Arjun
Rep Power: 34 |
Which flow model are you using with Fluent? Fluent with SA and coupled flow model on rae2822 was present as tutorial case so it does converge and converge pretty well if i remember correctly. With segregated version it has issues because when i made tutorial out of rae2822 for wildkatze (using SA model ) i noted that fluent's segregated solver had hard times (if at all converged). Wildkatze converges (with SA model) on rae2822 segregated solver but could have issues if settings are fiddled. |
divergence, transonic, turbulence |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
CFX Spalart Allmaras turbulence models | aweizazuji | CFX | 9 | September 24, 2013 10:53 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
