Wall distance?
Like Tree1Likes
  • 1 Post By Richard Howard
Old   February 22, 2000, 10:59
Default Wall distance?
stein lee
Hi, Guys,
Wall distance of each node is needed in some turbulent models. Who knows if the accuracy of wall distance is very important? How to compute the wall distances of the nodes in the wake of a profile or blade?
Thanks for your answers!
Stein
Old   February 22, 2000, 11:21
Default Re: Wall distance?
Richard Howard
There will undoubtably be lots of suggestions. Here is just one of many.
If the model parameter is based on y+ (the non-dimensional wall distance) this could be replaced by the 'turbulent Reynolds number' Ret=k^2/(nu e) where k is the turbulent kinetic energy, e the dissipation and nu the viscosity.
Ret behaves differently from y+ so you will probably need to add a constant in front of it. Ret has the nice characteristic in that it depends on the local turbulence and not the geometric.
A good reference if you can get hold of it is 'One point closures applied to transition', Transition and Turbulence modelling, ERCOFTAC book, kluwer, 1996 (but there are lots more studies around). regards, Richard
kusamanda likes this.
Old   February 22, 2000, 12:22
John C. Chien
(1). Each turbulence model will contain the complete information in regard to the wall boundary condition treatment. (2). In general, one must achieve mesh independent solution. Thus, there is no general answer to the mesh size requirement. (3). Approximate wall treatment (such as the wall functions) requires special guideline, which can only be obtained through experience with the particular class of problem being considered. (4). Specific formula sometimes are used in the in-house codes, but rarely available to general codes.
Old   February 22, 2000, 13:01
John Law
For many lower reynolds number turbulence models, the distance from a cell to a wall is needed (there are some models which use local turbulent Re as suggested by Richard). The general method is to calculate the distance of a cell to all walls and then take the minimum value of these distance - in this way, there is no problem if you have multi-walls.
Old   November 15, 2013, 22:26
Default Wall damping function
le hoang anh
lehoanganh07 is on a distinguished road
Could we use wall damping function or turbulent reynold number for K-epsilon model with high Reynold number? I saw that this method is used for low Reynold number?
lehoanganh07 is offline   Reply With Quote
calculating wall distance wallDist volker OpenFOAM Programming & Development 12 December 28, 2017 12:29
udf wall distance segmentation violation gento FLUENT 1 April 15, 2016 16:59
distance to wall in given direction nikwin OpenFOAM 3 February 16, 2012 10:27
cell to wall distance azmir Siemens 0 March 27, 2007 02:03
Distance to the nearest wall... Michal FLUENT 6 February 13, 2001 15:49
