Is there a specific term for this particular numerical error?
Like Tree3Likes
  • 1 Post By mprinkey
  • 1 Post By FMDenaro
Old   March 8, 2017, 10:52
Default Is there a specific term for this particular numerical error?
carl jung
carl jung is on a distinguished road
I have a question about the terminology.
Considering no slip condition, there is a huge difference in velocity between the wall and the fluid. If the grid is not fine enough near the surface, the gradient of the velocity will be a spike rather than a smooth peak. I think it's a kind of numerical error or discretization error, but is there any particular terminology about this?
Thank you,
Carl
carl jung is offline   Reply With Quote
Old   March 8, 2017, 11:06
Michael Prinkey
mprinkey will become famous soon enough
It is called "unphysical." If the flow is viscous and viscous effects are important to the flow, ignoring boundary layer behavior means the model fails to capture the flow dynamics. Pressure drops will be completely wrong, heat transfer rates will be completely wrong, etc. Failing to resolve diffusion layers in diffusion-domained processes ignores the principle physical effects.
Free slip conditions do make sense, say for external aero, when one is only calculating lift and drag results are not a consideration.
carl jung likes this.
mprinkey is offline   Reply With Quote
Old   March 8, 2017, 12:59
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I think that a correct terminology in CFD (and numerical analysis) is related to the concept of "insufficient resolution" in the representation of the solution. When the gradient is high, you can think to the function as represented by a large numbers of wavenumber components. Your large grid size cuts all wavenumbers greater than the Nyquist wavenumber. As mprinkey wrote, that leads to an unphysical smoothing of the velocity profile.
FMDenaro is offline   Reply With Quote
Old   March 8, 2017, 21:17
Default Thank you!
carl jung
Thank you all for the replies. There might not be an exact term for that. Is 'numerical diffusion' related to this?
Old   March 8, 2017, 22:44
Well, numerical diffusion is related to the type of the scheme that produces a term in the local truncation error that is similar to a diffusion. Considerino only the low resolution of a grid you cannot say it will produce a numerical diffusion.
Old   March 8, 2017, 22:46
carl jung
Thank you for the clarification!
discretization errors, grid, grid spacing, numerical error
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
