double-projection method that works on non-staggered grid |
February 11, 2017, 16:27 |
#1 | |
Bernd
Rep Power: 14 |
This is a follow up to a branch of another thread (i thought to open a new thread in order to not 'hijack' th other thread that originally had another topic)
In that thread we discussed Approximate Projection Methods (APM) and FMDenaro wrote: Quote:
I have one question: Am I correct to assume that for the second elliptic solve of the "double projection" one can get away with significantly fewer iterations of the linear solver to reach the error tolerance ? This would be important for the practicality of the method because typically already the first regular "single projection" solve takes most of the time of the whole simulation step. But if it would be possible to solve the 'second stage' of your double projection method with, say, only a limited number of additional gauss-seidel/jacobi sweeps or Conjugate-Gradient iterations then this would be a very interesting option to consider to improve my non-staggered approximate pressure correction method. |
February 11, 2017, 19:40 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
Of course, I used to start the iterations from the solution of the previous time step |
February 12, 2017, 04:10 |
#3 | |
Bernd
Rep Power: 14 |
I will try to digest the papers to better understand the details of the method. |
February 12, 2017, 04:23 |
Rep Power: 73 |
Ok, if you have questions you can ask for infos. The links of the two papers:
https://www.researchgate.net/publica...y-driven_flows https://www.researchgate.net/publica...ids?ev=prf_pub but I think that to understand better the theoretical basis of the DPM the details are here in this third paper https://www.researchgate.net/publica...ary_conditions |
Discretization of mass conservation equation in a 2D staggered grid | kiwiguigou | Main CFD Forum | 4 | April 16, 2016 15:57 |
projection method, commutator error | adamphy | Main CFD Forum | 2 | September 28, 2015 10:38 |
Parallel User Defined Real Gas Model | aeroman | FLUENT | 4 | July 1, 2015 06:09 |
How can i apply staggered grid method in circular domain? | heisenbergg | Main CFD Forum | 1 | April 1, 2010 17:05 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
