Solving Navier Stokes equations by projection method and predictor-corrector method.
Like Tree2Likes
  • 1 Post By zx-81
  • 1 Post By FMDenaro
Old   February 9, 2017, 05:47
Default Solving Navier Stokes equations by projection method and predictor-corrector method.
Saideep
Saideep is on a distinguished road
Hi guys;
I am comparing two different CFD packages. OpenFoam and Gerris for studying two phase immiscible flow.
According to OpenFOAM, the Navier Stokes equations are solved using a "Predictor-Corrector" step using PISO loop.
In Gerris, the Navier Stokes equations are solved by a "time splitting Projection" method.
Though from my understanding the summary of both the methods are the same:
1. Using an initial guess of pressure find an intermediate velocity (which considers the viscous and convective terms of present time step) field that is not mass conservative;
2. Using the non-divergent velocity field, update the pressure field by solving "Poissons equation";
3. With known data on the correct pressure for present time step along with intermediate velocity field known update a mass conservative velocity field.
However, I am unable to catch the difference between Chorin's projection method and Issa's PISO loop.
Can anyone help me out?
Thanks;
SaiD
Saideep is offline   Reply With Quote
Old   February 9, 2017, 08:36
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Projection methods are based on the Hodge decomposition: in each time step, the intermediate velocity is projected onto the subspace of divergence-free velocity field by solving the Poisson equation. That is solved only once in each time step and is not iterated in "outer" iteration.
FMDenaro is offline   Reply With Quote
Old   February 9, 2017, 09:44
Kaya Onur Dag
kaya is on a distinguished road
Originally Posted by Saideep View Post
Hi guys;
Thanks;
SaiD
have a look at the red ferziger, this is covered in that book and explanations are very easy to get
kaya is offline   Reply With Quote
Old   February 9, 2017, 10:14
Saideep
Hi Denaro & Kaya;
Thanks for your reply.
PISO is an iterative approach (we specify number of pressure correction). The more corrections we make for Pressure the more accurate the divergence free flux we get.
Unlike, Projection is a single step method with pressure fixed upon reaching suitable specified tolerance limit. (I am not well versed by Hodge decomposition but I understand the velocity is decomposed into a divergence free term which we are interested in and a pressure term. What I understood from Wiki)
So, to conclude: Projection method = 1 PISO loop. Then, is PISO a more powerful approach to get a better conservative flux if both the methods have a fixed tolerance limit set by me.
Thanks Kaya I will have a look right now.
Old   February 9, 2017, 12:39
Well, more in details, we call Exact projection method when in a single step the divergence-free constraint is satisfied up to machine accuracy while the Approximate projection method is satisfied only up to the order of the local truncation error.
However, since the Hodge decomposition is well posed setting only one boundary condition, any projection method suffers from an approximation in the setting of the tangential condition.
On the other hand, PISO as well as other coupled method iterate continuity and momentum until the desired convergence is reached.
Old   February 10, 2017, 18:31
Bernd
zx-81 is on a distinguished road
As the OP mentioned the Gerris package it's worth noting that Gerris also uses an approximate pressure correction because approximate corrections can be stably used with co-located, i.e. non-staggered velocity grids which in turn allows for more efficient implementation of the adaptive, octree based grid structure.
FMDenaro likes this.
zx-81 is offline   Reply With Quote
Old   February 10, 2017, 18:43
Yes, the original nature of the APM is for colocated grid with compact stencil for the pressure equation but it can be extended easily to general unstructured grids. However, an EPM can be implemented on non-staggered grids, too.
Old   February 10, 2017, 19:10
Bernd
That sounds interesting as it was my impression that any non-staggered grid scheme is supposed to be vulnerable to pressure instabilities/oscillations when using the exact, i.e. non-compact stencil. The only 'work-arounds' I heard of so far are the approximate correction APM and "Rhie Chow"-like interpolation schemes ...
In my personal experience I have found that the APM is stable and only shows small divergence errors in the highest frequencies (wave numbers) of the solution but over all the computed flow is practically indistinguishable from the solution obtained via exact pressure projection.
However, severe pressure oscillations did appear with the APM derived pressure when used with the itarativ pressure correction method (i.e. when one solves the poisson equation not for the pressure but for a pressure increment )
Old   February 10, 2017, 19:19
Yes, some years ago I worked a lot on this issue ... The APM produced some of these problems in my LES code and I wanted not to use the RC-interpolation to not introduce artificial dissipation. Thus, I developed an exact double-projection method that works on non-staggered grid. I had good and oscillation-free solutions without adding dissipation. The general idea can be implemented also on triangular (tetraedra in 3d) unstructured grids. If you are interested, you can find a couple of my published papers on IJNMF
mprinkey likes this.
Old   February 13, 2017, 09:16
Michael Prinkey
mprinkey will become famous soon enough
I'm looking forward to reading those papers, Professor. I have never liked using RC for the reasons you cite.
mprinkey is offline   Reply With Quote
Old   February 13, 2017, 11:29
we are discussing here:
navier stoke solver, piso, projection method
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Projection method and mesh free Rime Main CFD Forum 7 June 15, 2015 15:43
New sixDoFRigidBody BC working with laplaceFaceDecomposition Ya_Squall2010 OpenFOAM Running, Solving & CFD 13 April 17, 2013 03:04
help: I am trying to solve Navier Stokes compressible and viscid flow Jose Choy Main CFD Forum 2 May 18, 2000 06:45
Laplace or Stokes equations solver by Boundary Elements Method Lemonnier Main CFD Forum 3 December 28, 1999 14:48
