laminar model used for turbulent flow
Like Tree1Likes
  • 1 Post By FMDenaro
Old   December 3, 2016, 04:28
Default laminar model used for turbulent flow
raunak jung pandey
raunakjung is on a distinguished road
How are the Navier stokes equations solved in Navier Stokes equtions solved when laminar model is used ?
What happens when turbulent conditions are solved using Laminar model ?
Thank You
raunakjung is offline   Reply With Quote
Old   December 3, 2016, 05:32
Antanas is on a distinguished road
Thank You
Laminar model means that full non-averaged N-S equations (not RANS) are solved. It will resolve all turbulent scales except subgrid scales. Generally it's not easy and costly. So its better to use laminar model when flow is really laminar.
Antanas is offline   Reply With Quote
Old   December 3, 2016, 16:51
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
The original NS equations are valid independently from the regime of the flow. Laminar, transitional and turbulent flows can be simulated provided you have a so fine grid to resolve all characteristic scales (DNS).
lcarasik likes this.
FMDenaro is offline   Reply With Quote
Old   December 3, 2016, 20:08
raunak jung pandey
I tried using LES in a laminar condition and the results are similar to when using a laminar model . What does this result means ?
Old   December 4, 2016, 04:42
Nothing particular, the LES code is well written
Old   December 4, 2016, 05:08
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
You should really stop using the term laminar "model". The point of a direct numerical simulation (DNS, what you refer to as laminar "model") is that there are no additional models necessary. The Navier-Stokes equations are solved directly.
flotus1 is offline   Reply With Quote
laminar, turbulence, turbulence modelling
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 09:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Using a turbulent model when the flow is entirely laminar. mwhyte FLUENT 1 June 7, 2012 11:35
Is this understanding of turbulence models correct? 3kha Main CFD Forum 3 January 31, 2011 22:31
Laminar flow in species transport model? Neha Rao FLUENT 7 February 25, 2006 03:23
