December 3, 2016, 04:06 |
Sealant Efficiency
Iman
Rep Power: 12 |
Dear All,
Say, there is an small hole in a pipe, through which oil leaks (the gray pipe in the middle of attached photo). The hole will be sealed using a sealant. Now we need to know how long the sealant can withstand by means of CFD simulation. All the boundary conditions and the properties of oil and sealant are known. Is it any way that we can do it by CFD? Can we use CFD free surface software? I will appreciate your help. |
December 3, 2016, 17:42 |
Mohan Kumar Gajendran
I am no expert in this field, i will tell what comes to my mind, I would approach sealant structurally, I will find the fatigue life of sealant, and rate of detoration with loading, and we can find the forces acting on sealant from Cfd. Then you shall need to couple it with a structural or fatigue solver.
December 4, 2016, 02:57 |
#3 | |
Iman
Rep Power: 12 |
Many thanks for your comment. It gave me some ideas. |
leakage, sealant |
Centrifugal Compressor Efficiency | albertotato | CFX | 3 | May 2, 2020 03:54 |
Axial fan Efficiency Goals calculation? | Sanghyun - PARK | FloEFD, FloWorks & FloTHERM | 1 | February 18, 2013 12:20 |
centrifugal Pump Efficiency | A.farid | Main CFD Forum | 0 | March 31, 2012 08:39 |
Efficiency, thrust/drag with regard to hovering | quarkz | Main CFD Forum | 0 | April 21, 2010 01:51 |
Parelleling Efficiency | kassiotis | OpenFOAM | 0 | June 19, 2009 15:12 |
