Comparison between Fluent and Autodesk CFD
Like Tree2Likes
  • 1 Post By tas38
  • 1 Post By huangyuan18
Old   November 11, 2016, 10:08
Question Comparison between Fluent and Autodesk CFD
aekinci's Avatar
aekinci is on a distinguished road
Hi Guys,
I am working on CFD tool hunting for my company. Now I have two candidates: Fluent and Autodesk CFD. Of course money talks, Fluent is much more expensive than Autodesk CFD. But I need some information about their accuracy, ease of use etc. Could anyone here having experience with either of these two give me some hints? We need the tool for wind turbine rotor design and optimization.
Many thanks!
aekinci is offline   Reply With Quote
Old   November 11, 2016, 11:15
Troy Snyder
tas38 is on a distinguished road
I have used Fluent but not Autodesk CFD. In purchasing the software, I am not sure if you can license Fluent standalone, but are required to purchase and general ANSYS license. In any case, Fluent/ANSYS are quite robust, easy to use, and the documentation is extensive. As a matter of fact, ANSYS Fluent has its own forum on this site, which is indicative of its pervasive use in academia and industry. This software should be able to handle the wind turbine design problem you speak of.
Regarding Autodesk CFD, if it is anything like Solidworks flow simulation, I would not purchase it. Solidworks flow simulation does too much "behind the scenes" and automated so you can get "a solution" whether or not it is a "good solution". With ANSYS Fluent or any dedicated CFD software, you have much more control.
lcarasik likes this.
tas38 is offline   Reply With Quote
Old   November 14, 2016, 18:05
Pawel Zdunek is on a distinguished road
I am no expert but wind turbine rotor design and optimization sounds like a very serious job so I guess I would go with the fluent. I mean fluent is better than autodesk cfd (for example you don't have hex mesh, only tetrahedrons in autdesk), but it requires much much more skilled staff. I guess you need to determine if autodesk will do the job, so if i were you i would ask the distributor if they did any experimental comparison of their results in similar case and if they know if anybody did a job like that and i would definitely like to see the report, rather than hear "results were ok".
Man, I would maybe even ask them to do a simulation representing the one you guys will do and check how results align with data (to have relevant data the case they do should be very popular like airfol, subsonic-supersonic nozzle flow problems etc.).
I'm pretty sure you don't get to choose turbulence models in autodesk, so i wouldn't be surprised if cfd engineers from here would diqualify autodesk for that, but hey it is an optimization problem - fluent costs more, requires more input (skills and time) from user and is used for stuff like that, autodesk is cheaper, user friendly but you don't know if you can trust it. You can also check out ansys cfx, there is also helyx engys.
Pawel Zdunek is offline   Reply With Quote
Old   November 18, 2016, 10:07
Ryan Huang
huangyuan18 is on a distinguished road
I agree most of the comments above, but just be fair Autodesk CFD does have option to choose turbulence model.
Pawel Zdunek likes this.
huangyuan18 is offline   Reply With Quote
Old   April 20, 2018, 10:25
CFDfan is on a distinguished road
I haven't used Autodesk CFD but used its predecessor CFdesign in my previous job. It had really crappy solver and mesher, though very user friendly interface. Don't believe Autodesk has improved the solver and the mesher, so it is most probably still crappy in terms of the reliability and accuracy. I remember running the same model with different versions of CFDesign and getting quite different results, rarely aligning with reality. For the last 15 years I've been using Flowsimulation and scStream and found those to be much more reliable and trustful (and less expensive).
CFDfan is offline   Reply With Quote
autodesk cfd, fluent
How to import a Revit model to Fluent? qzsky FLUENT 0 June 5, 2013 13:30
Which CFD Software is batter?? addy01 Main CFD Forum 5 February 28, 2013 21:09
Please help me, I know nothing about CFD ben1793 Main CFD Forum 13 September 28, 2012 18:22
How to import Autodesk Inventor .ipt file into ANSYS FLUENT? soetommy FLUENT 0 September 27, 2011 01:35
Which CFD package to buy? Vishal Jariwala Main CFD Forum 9 February 29, 2008 18:32
