problem in mesh and FORTRAN 77 code
Like Tree2Likes
  • 1 Post By FMDenaro
  • 1 Post By mostanad
Old   September 5, 2016, 14:01
Default problem in mesh and FORTRAN 77 code
mohammad
mostanad is on a distinguished road
Hello everybody
my master give me a fortran code that can produce for me a arbitrary shape and grid it. the code is about 3000 lines and i don't know so about it. my problem is the algorithm of giding tha it used. because i want change it. my master say that it solve laplace equation. also maybe use "body generating cordinate system" technique for meshing. did any body hear these names?. is it a known algorithm. is any book that can help me? I write some lines of code to see it.
      WRITE(*,1)NSEC
    1 FORMAT(/,10X,'SPECIFY NO OF SECTIONS FOR',
     1             ' NORTH BOUNDARY, (MAX  ',I2,' )')
      READ(*,*)LSCN
      DO L=1,LSCN
      WRITE(*,2)L
    2 FORMAT(/,'SECTION',2X,I2,5X,'IF LINEAR TYPE 1,  ',
     1                   'IF CIRCULAR ARC 2')
      READ(*,*)ISHP(L)
      IF(L.EQ.1)THEN
      WRITE(*,3)L
    3 FORMAT(/,5X,'INPUT STARTING X POSITION FOR SECTION  ',I3)
      READ(*,*)X1(L)
      WRITE(*,4)L
    4 FORMAT(/,5X,'INPUT STARTING Y POSITION FOR SECTION  ',I3)
      READ(*,*)Y1(L)
      ENDIF
      IF(L.GT.1)THEN
      X1(L)=X2(L-1)
      Y1(L)=Y2(L-1)
      ENDIF
      WRITE(*,5)L
    5 FORMAT(/,5X,'INPUT  X POSITION AT END OF SECTION  ',I3)
      READ(*,*)X2(L)
      WRITE(*,6)L
    6 FORMAT(/,5X,'INPUT  Y POSITION AT END OF SECTION  ',I3)
      READ(*,*)Y2(L)
      IF(ISHP(L).EQ.2)THEN
      WRITE(*,7)
    7 FORMAT(/,5X,'SPECIFY ANGLE OF ARC IN DEGREES')
      READ(*,*)THT(L)
      THT(L)=3.142*THT(L)/180.
      WRITE(*,8)
    8 FORMAT(/,5X,'FOR CONVEX ARC TYPE 1 AND FOR CONCAVE 2')
      READ(*,*)IARC(L)
      END IF
      END DO
   10 CONTINUE
      DO L=1,LSCN
      WRITE(*,9)L
    9 FORMAT(//,10X,'SECTION',3X,I2,5X,'SPECIFY NUMBER OF  INTERVALS')
      READ(*,*)LSTP(L)
      LSTPN(L)=LSTP(L)
      ENDDO
      LSTPT=LSTP(1)
      DO 200 L=2,LSCN
      LSTPT=LSTPT+LSTP(L)
  200 CONTINUE
      MD=MI-LSTPT
C      IF((LSTPT+1).NE.MI) THEN
      IF(MD.NE.1)THEN
      WRITE(*,11)LSTPT,MI
   11 FORMAT(/,3X,'** ERROR',5X,'INTERVALS ',I2,5X,'POINTS ',I2,3X,
     1       '***')
      GO TO 10
      END IF
      NCOUNT=1
      XCN(1)=X1(1)
      YCN(1)=Y1(1)
      DO L=1,LSCN
      IF(ISHP(L).EQ.1) THEN
      DO LL=1,LSTP(L)
      NCOUNT=NCOUNT+1
      XCN(NCOUNT)=XCN(NCOUNT-1)+ (X2(L)-X1(L))/FLOAT(LSTP(L))
      YCN(NCOUNT)=YCN(NCOUNT-1)+ (Y2(L)-Y1(L))/FLOAT(LSTP(L))
      ENDDO
      ENDIF
       XM=.5*(X1(L)+X2(L))
       YM=.5*(Y1(L)+Y2(L))
      S1=SQRT((X2(L)-XM)**2+(Y2(L)-YM)**2)
      R=S1/SIN(.5*THT(L))
      EL1=SQRT(R*R-S1*S1)
      ELSA=EL1/S1
      XCEN1=XM+ELSA*(YM-Y1(L))
      YCEN1=YM-ELSA*(XM-X1(L))
      XCEN2=XM-ELSA*(YM-Y1(L))
      YCEN2=YM+ELSA*(XM-X1(L))
      IF(IARC(L).EQ.1)THEN
      IF(YCEN1.GE.YM)THEN
      YCEN=YCEN1
      XCEN=XCEN1
best regards.
mostanad is offline   Reply With Quote
Old   September 5, 2016, 14:50
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Give a look to this book
http://www.erc.msstate.edu/publicati...ook/chap06.php
FMDenaro is offline   Reply With Quote
Old   September 5, 2016, 14:59
mohammad
Originally Posted by FMDenaro View Post
thanks
do you know this algorithm? or you say "this algorithm might be exist in this book"
Old   September 5, 2016, 15:29
As you wrote "Laplace equation" you should see it in the chapter of Elliptic grid generation
ssh123 likes this.
Old   September 5, 2016, 16:26
mohammad
thanks alot Prof Denaro
FMDenaro likes this.
fortran code to read mesh HaKu Main CFD Forum 3 December 15, 2020 14:13
how can i find source fortran code for moving mesh? big-bang Main CFD Forum 0 December 3, 2015 21:04
gmsh2su2 mesh converter Fortran source code ceanwang SU2 1 February 20, 2013 03:17
biCGSTAB Fortran code, unstructured mesh Nico Main CFD Forum 4 September 12, 2006 12:12
Moving Mesh Problem in Unix Platform Arnab Siemens 3 August 16, 2004 09:59
