Turbulence Modeling
Like Tree1Likes
  • 1 Post By davidwilcox
Old   September 1, 2016, 18:07
Default Turbulence Modeling
Hossein Mirabi
Hossein Mirabi is on a distinguished road
Does anybody have some CFD and experimental data that shows which of three pressure strain models in Reynolds Stress Model has more accuracy in fully turbulent region?
Hossein Mirabi is offline   Reply With Quote
Old   September 2, 2016, 06:38
david
davidwilcox is on a distinguished road
Here's one. This is for stagnating flows though.
Analysis of Impinging and
Countercurrent Stagnating Flows
by Reynolds Stress Model
YH Im, KY Huh, KY Kim
Note that if you're planning to do rotational flows, most RSM models are not frame invariant.
Hossein Mirabi likes this.
davidwilcox is offline   Reply With Quote
Old   September 2, 2016, 06:48
Hossein Mirabi
the problem is about the natural behavior of anisotropic turbulent regime at for instance established region of a confined submerged jet. all three pressure strain models in RSM can use for CFD modeling, but the accuracy of each model is the point. my research shows that the GL Pressure Strain has good accuracy in this kind of flow in compare with experimental data. so i want to know anybody has same research in this field and what is the result.
Old   September 7, 2016, 15:07
Default RSM/GL Pressure Strain Model - Jet at Sudden Expansion
Hossein Mirabi
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Turbulence Modeling meshkati FLUENT 1 October 3, 2016 07:11
Which Turbulence modeling???? Yapoo FLUENT 2 October 2, 2016 03:29
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 12:48
