Reading a mesh from a CGNS file
Like Tree2Likes
  • 2 Post By t.teschner
Old   August 3, 2016, 03:27
Default Reading a mesh from a CGNS file
Chaithanya
chaithu is on a distinguished road
I have just started learning CFD. I just learnt the algorithm for structured non-orthogonal grids. I would like to implement them in C++, but I have no idea as to how to read the mesh file created in ICEM CFD into my C++ code.
Can someone please help me out.
Thanks in advance.
chaithu is offline   Reply With Quote
Old   August 4, 2016, 17:01
Lightbulb Use MSH File
Pflaume1891 is on a distinguished road
Hi.
I'd advice you to use msh file for two reasons:
1. MSH Files are documented in the ANSYS Help. Look for it under
Appendix B. ANSYS Fluent File Formats
2. You can choose to output msh files in ascii format - that is more
easy to implement first. After it's functioning, you can also write a
algorithm for binary files - is also documented in the ansys help.
Regards,
Jan
Pflaume1891 is offline   Reply With Quote
Old   August 7, 2016, 19:39
Tom-Robin Teschner
t.teschner is on a distinguished road
Having used CGNS extensively, I would tend to agree that something like the fluent *.msh file is probably something easy to start with, or maybe the star ccm format as well, but that is up to you. if you want to get started with cgns, i highly recommend to go through the user guide (it is not that long but in my opinion worthwhile to learn, cgns can greatly simplyfy thing for you in the future, but it also can be tricky at times)
http://cgns.github.io/CGNS_docs_curr...uide.3.1.3.pdf
now, if you want to continue down the cgns path, here are a few simple subroutines which will read the coordinates for you (its all c++, arrays and variables have been declared before elsewhere) and set up the boundary conditions.
#include <iostream>
#include "stdio.h"
#include "cgnslib.h"
#include "readmesh.h"
using namespace std;
void get_mesh_sizes(char *name, int **isize)
	int 	index_file;
	char 	zonename[100];
	cg_open(name,CG_MODE_READ,&index_file);
	cg_zone_read(index_file,1,1,zonename,isize[0]);
	cout << "number of vertices: " << isize[0][0] << endl;
	cout << "number of cells:    " << isize[0][1] << endl;
	cg_close(index_file);
void read_coordinates(char *name, float *x, float *y, int **con, int **isize)
	int 			index_file,irmin,irmax,istart,iend,nbndry,iparent_flag,iparentdata;
	int 			*ielem, counter;
	ElementType_t 	itype;
	char 			sectionname[100];
	irmin = 1;
	irmax = isize[0][0];
	ielem = new int[isize[0][1]*3];
	cg_coord_read(index_file,1,1,"CoordinateX",RealSingle,&irmin,&irmax,x);
	cg_coord_read(index_file,1,1,"CoordinateY",RealSingle,&irmin,&irmax,y);
	cg_section_read(index_file,1,1,1,sectionname,&itype,&istart,&iend,&nbndry,&iparent_flag);
	cg_elements_read(index_file,1,1,1,&ielem[0],&iparentdata);
	counter = 0;
	for (int i = 0; i < isize[0][1]; i++)
		for (int j = 0; j < 3; ++j)
			con[i][j] = ielem[counter];
			counter += 1;
int get_bc_num(char *name)
	int index_file,nbocos;
	cg_nbocos(index_file,1,1,&nbocos);
	return nbocos-1;
int get_bc_ind_num(char *name, int ib)
	int 			normalindex[3],ndataset;
	char 			boconame[100];
	BCType_t 		ibocotype;
	PointSetType_t	iptset;
	cgsize_t 		npts,normallistflag;
	DataType_t 		normaldatatype;
	cg_boco_info(index_file,1,1,ib,boconame,&ibocotype,
                   &iptset,&npts,normalindex,&normallistflag,&normaldatatype,&ndataset);
	return npts;
void read_bc_conditions(char *name, int **bc)
	int 			index_file,nbocos,normallist;
	char 			boconame[100];
	BCType_t 		ibocotype;
	cgsize_t 		*ipnts;
	for (int ib = 2; ib <= nbocos; ib++)
		ipnts    = new cgsize_t[npts];
		cg_boco_read(index_file,1,1,ib,ipnts,&normallist);
		for (int i=0; i < npts; i++)
			bc[ib-2][i] = ipnts[i];
		delete ipnts;
note that normally you have a tree like structure in cgns, i.e. each cgns file can have bases under which are zones which then contain mesh coordinates and boundary conditions. think of it this way, if you have a moving mesh (which is remeshed at each timestep) then you would put each mesh for each timestep under one separate base. now each base in turn has zones, which for unstructured meshes are usually one, but if you have a structured mesh, you can have several blocks which would all sit under one zone. therefore, only under each zone you will find the coordinates and boudnary conditions. the above assumes you are using a single block (number of zones = 1) and no moving mesh (bases = 1) so that is why you will see most api calls starting with cg_function_name(index_file,1,1, ...) which basically means cg_function_name(index_file,index_base,index_zone, ...). also have a look at the api call references to check what you need to pass to functions and what parameter they require.
http://cgns.github.io/CGNS_docs_curr...vel/index.html
how as for the mesh above, get_mesh_sizes() will read the number of vertices and cells from a cgns file, read_coordinates() will read the arrays x and y holding the coordinates whereas ielem holds the lookup table to reconstruct the cells from the coordinates. i then rearrange it into the con array, which has dimensions of con[number_of_cells][number_of_vertices_per_element], here i use tri elements (3 vertices per element, therefore the 3). if you have more elements (tri, hexa ...), then you would need to inquire about them first (and you would probably also have two zones so you would need to get the number of zones as well, that all depends on the implementation from the mesh generator, see also below). get_bc_num() reads the number of boundary conditions and get_bc_ind_num() gives the number of elements making up that boundary (this function is called for each boundary condition). read_bc_conditions() reads the nodes which are on the boudnaries, note that i don't use ibocotype here but that would be the one to check which boundary condition to apply (in my case it was all walls so i didn't bother in this simple example).
the above worked for me when creating meshes with icem but i have to sat/stress at this point that a lot of people are contributing to cgns and everyone seems to have a different understanding of cgns. so for example, while the above was working for me using icem, i would be surprised if it would work out of the box for any other mesh generator. in fact, pointwise is interpreting the boudnaries to sit under the section and family nodes (which is permitted but confusing) and so if you wanted to have a general mesh reader, cgns will have a lot if case checking involved (i.e. which mesh generator was used and then tailoring the mesh reading part for them). similar things i noticed with reading solution files (based on cgns), while tecplot seems to have a proper understanding of cgns and implemented them will for what i can tell, paraview did a lousy job and you will only really be able to show the solution of a single file, good luck trying to get an animation with paraview, that has caused me several days/nights only to realise that it is not working/implemented in paraview ... but thats just a word of caution, overall i still use that format because, after all, if you know how it works, it is really powerful and can simplify things like mesh reading a lot
dupeng and snowquote like this.
t.teschner is offline   Reply With Quote
Old   July 19, 2019, 11:17
vidyadhar
vidyadhar is on a distinguished road
Hello Tom-Robin Teschner,
I have fluent case and data files read into Paraview. Now I have done some basic operations in paraview and left with certain part of the original domain.
I want this remaining part from paraview to be loaded into Fluent.
I am using save data option in paraview which saves in .cgns format.
But when I try to import this file, Fluent is giving errors and not reading the file.
I request your comments whether this is a correct procedure?
Thanks in advance!
vidyadhar
vidyadhar is offline   Reply With Quote
Old   July 19, 2019, 21:13
Tom-Robin Teschner
Well if you would specify what "basic operations", "certain part" and "giving errors" means in your case maybe I can help but you have to be more specific. With the information given I can only assume that your file is not compliant with what fluent expects. Maybe paraview is not writing out the boundary conditions, or writing them as a family node and not a BC node... Several possibilities, the best chance you have is to compare the raw cgns file from fluent and paraview with cgnscheck or cgnsview (for that you have to download cgns and compile the library, this utilities will then be placed in the tools folder) and see the differences in the cgns tree
cfd.university
Old   July 20, 2019, 05:39
vidyadhar
Thanks for the response.
1) I have exported Fluent solution data in Encase Gold Format and opened in Paraview. It displays "invalid VARIABLE line:SCRIPTS". But, I can perform all basic operations like clipping, iso-contours etc.
2) Even without performing any of the above "basic operations", I have done this in paraview: File --> Save Data --> .cgns file
But, when I try to import this cgns file into Fluent, it displays an error message saying "Error reading cgns file"
3) My intention was to CLIP vapor cells by a scalar of volumefraction=0.5 and save the data in cgns format, so that in Fluent I can read this and perform further simulations.
My queries: Whether saving data in CGNS format from paraview results in saving mesh&data at all the cells of the domain or only at the boundaries?
Thanks & Regards,
Vidyadhar
[Moderator note: Related thread: How to export from Paraview to ANSYS or any software for performing Meshing ]
Old   July 20, 2019, 20:47
Tom-Robin Teschner
First off all, from your last answer I can see that your problem is not related to the original question. In the future, please open a new thread here on CFD online.
Secondly, how do you expect your work flow to work, if the simple import /export without any operations is not even working? Thirdly, I think what you are trying to achieve cannot be done in paraview (my best guess, anyways), paraview is only for visualisation. Sure, you can modify data and even export that, but how should fluent be able to interpret the new data you give it? Without having seen how paraview would export a clipping plane /iso contours etc. I would assume it will only export the locations with the value attached to it, not the whole mesh. I think what you need are user defined functions in fluent so that the solver knows what you want to do. If I were you I would consult the fluent forum here and see what that community would recommend.
cfd.university
Old   April 13, 2024, 17:51
Tom-Robin Teschner
Just an update after some years: I have been working on a much more elaborate answer to this question and I have posted it at here. This includes:
  • How to read a multi-block structured grid
  • How to read a multi-block unstructured grid
  • How to read boundary conditions for either structured and unstructured grids (including family and non-family boundary nodes which are specific to CGNS)
  • How to handle interfaces between different blocks for both structured and unstructured grids
  • A brief history and development of the CGNS file format
A walkthrough of the code is provided and the code can be downloaded and used directly in any project.
cfd.university
c++, cgns, icem cfd
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
