Time derivative of pressure in low mach number approximation |
June 16, 2016, 06:34 |
SAM
Rep Power: 14 |
Dears
I have a question regarding the time derivative of pressure in low-Mach number approximation of NS equations. Referring to the work " Numerical study of a channel flow with variable properties" done by Nicoud, depending on the whether the simulation system is closed or open, the time derivative of pressure can be defined as ... (see the equation 8 of his paper) for closed system or zero for open system. Could somebody tell me why for open system this is zero? Thank you all |
June 16, 2016, 08:05 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 19:32 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 15:49 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
