A simple question about adding Div and Grad of a source term to the momentum equation |
May 22, 2016, 10:02 |
Adkar
Rep Power: 11 |
Hello foamers, I have a simple question regarding writing equations in OpenFoam. Could anybody please help me understand this?
I would like to write an equation like the following where I have to add div A and grad A to U equation. Here, A is set in boundary condition. But when I solve this Equation, it gives me the same result as momentum equation without the addition of these two terms. Here div (constant1, A) - grad (A) acts something like opposing force. Do I have use fvc::Su () or fvc:: Sp ()? like fvc::Su(fvc::div(constant1, A) - fvc::grad(A) ) Or am I missing something very basic? I am not sure how to write this piece of code. Please see the following code: ****************************************: fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) ); solve(UEqn == -fvc::grad(p) + fvc::div(constant1, A) - fvc::grad(A); Then goes the Piso loop to couple p and U without A getting involved. ******************************************** Thank you in advance |
May 23, 2016, 03:37 |
Adkar
Rep Power: 11 |
Could anybody please help??
May 23, 2016, 04:24 |
adrin
Rep Power: 17 |
I don't know much about openfoam, neither is it obvious what you're trying to achieve. But, I have a more fundamental question/concern regarding what you're trying to do.
It's possible openfoam's objects have certain (unusual) overloading options, but from equation -fvc::grad(p) + fvc::div(constant1, A) - fvc::grad(A); I can only suggest that you consider the accuracy of your formulation first, because: grad(p) is a vector, and if A is a vector then div(A) is a scalar and grad(A) is a tensor. If A is a tensor then div(A) would be a vector but grad(A) would still not be correct. So, again, unless openfoam's objects have certain optional capabilities that allow one to do poor math you have a serious rank mismatch, both physically and mathematically. adrin |
May 23, 2016, 08:23 |
#4 | |
Adkar
Rep Power: 11 |
The actual code is the following from mhdFoam solver. Could you please be kind enough for having a look at it one more time? B is a vector used in the boundary condition. Eg. (0 20 0) My problem is that when I remove the B-Piso loop part, the solver will not calculate the effect of the extra terms in the momentum equation. Am I missing something? Please help. Any help is appreciated. Thank you very much. Code:
///////////////////////////////////////////////////////////////////////////////////////////////////////////// #include "fvCFD.H" #include "OSspecific.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "createFields.H" #include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< nl << "Starting time loop" << endl; while (runTime.loop()) { #include "readPISOControls.H" #include "readBPISOControls.H" Info<< "Time = " << runTime.timeName() << nl << endl; #include "CourantNo.H" { fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvc::div(phiB, 2.0*DBU*B) //Extra term// - fvm::laplacian(nu, U) + fvc::grad(DBU*magSqr(B)) //Extra term// ); solve(UEqn == -fvc::grad(p)); // --- PISO loop for (int corr=0; corr<nCorr; corr++) { volScalarField rAU(1.0/UEqn.A()); volVectorField HbyA("HbyA", U); HbyA = rAU*UEqn.H(); surfaceScalarField phiHbyA ( "phiHbyA", (fvc::interpolate(HbyA) & mesh.Sf()) + fvc::ddtPhiCorr(rAU, U, phi) ); for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( fvm::laplacian(rAU, p) == fvc::div(phiHbyA) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); if (nonOrth == nNonOrthCorr) { phi = phiHbyA - pEqn.flux(); } } #include "continuityErrs.H" U = HbyA - rAU*fvc::grad(p); U.correctBoundaryConditions(); } } /* // --- B-PISO loop /////// I tried to remove this part of B-PISO loop since I would only need the first /////// equation and the B-Piso loop part would take too much time for calculation ///////and its effect is very less. B is given by boundary condition. for (int Bcorr=0; Bcorr<nBcorr; Bcorr++) { fvVectorMatrix BEqn ( fvm::ddt(B) + fvm::div(phi, B) - fvc::div(phiB, U) - fvm::laplacian(DB, B) ); BEqn.solve(); volScalarField rBA(1.0/BEqn.A()); phiB = (fvc::interpolate(B) & mesh.Sf()) + fvc::ddtPhiCorr(rBA, B, phiB); fvScalarMatrix pBEqn ( fvm::laplacian(rBA, pB) == fvc::div(phiB) ); pBEqn.solve(); phiB -= pBEqn.flux(); #include "magneticFieldErr.H" } runTime.write(); } */ Info<< "End\n" << endl; return 0; } ////////////////////////////////////////////////////////////////////////////////////////////////////////////// |
May 23, 2016, 14:15 |
Filippo Maria Denaro
Rep Power: 73 |
May 23, 2016, 18:31 |
adrin
Rep Power: 17 |
As I mentioned earlier, I'm not familiar enough with openfoam to be of help there. But there is actually an openfoam-specific forum on cfd-online, which I strongly recommend you post your question(s) to. I'm sure openfoam has its own user forum as well, so you're strongly recommended to try them as well
adrin |
Source term in the compressible momentum equation | dduque | OpenFOAM Programming & Development | 2 | April 10, 2015 05:58 |
