Quasi 1D Nozzle Shock Capturing MacCormack Method Problems
Like Tree2Likes
  • 2 Post By matt1234
Old   May 20, 2016, 13:55
Default Quasi 1D Nozzle Shock Capturing MacCormack Method Problems
Matt
matt1234 is on a distinguished road
Hi I am new to CFD, and I have been using the introductory book by Anderson.
It has multiple cases for a Quasi 1D Nozzle, and I am completely stuck on the Shock Capturing Case (7.6).
It is done using a MacCormack method with added artificial viscosity in conservation form and a constant exit pressure ratio of 0.6784.
I have tried as exactly presented in the book (I think) as well as have tried many other approaches to see if I could fix it. No matter what, my code diverges after about 25 time steps.
Has anybody successfully solved this code?
If so, can you please show me the code?
I would prefer MATLAB, but any computing language is fine.
This is driving me crazy!
Or, if anybody as another code that solves this problem (not necessarily MacCormack method) please provide it to me.
Please post here or feel free to email it to me: mbyoung18@hotmail.com
Thank you so much!
matt1234 is offline   Reply With Quote
Old   May 20, 2016, 22:16
LUQILIN
LUQILIN is on a distinguished road
General finite volume scheme could catch the shock but with numerical oscillations at discontinuities. Try this first. Just ignore the shock and see what you can get. You can e-mail to me if you have further questions: luqilin@hrbeu.edu.cn.
LUQILIN is offline   Reply With Quote
Old   May 22, 2016, 09:30
Default I have encountered same problem
Ramkumar
Ramkumar21194 is on a distinguished road
i have done same problem in matlab using same Mccormack technique as described in Ch7. my problem is, i encounter -ve temperature in about 100th iteration step. i dont know why, could you please help me with this?
i have solved the rest of the problems in CH7. this one is driving me crazy
i think the problem is in extrapolation in outlet.
please help me with this.
here is my code
Ramkumar21194 is offline   Reply With Quote
Old   May 22, 2016, 09:40
Ramkumar
upload your matlab code matt, i wanna take a look at it
Old   July 7, 2017, 05:04
Yaser
Haider58 is on a distinguished road
Hay ramKumar..
Its been a year now. Have you been able to resollve bug in your code. Can you please share it.
Thanks
Haider58 is offline   Reply With Quote
Old   July 19, 2017, 02:38
ardalan khalili
ardalankhalili is on a distinguished road
hey rumkummar
im facing the same problem so i was wondering if you resolved this problem yet? my solution diverges after about 100 iterations and the results are not anywhere near acceptable... i think my problem is at subsonic outflow boundaries that need to float (as the anderson says).
please let me know if you had any progress.
thanks.
ardalankhalili is offline   Reply With Quote
Old   October 23, 2019, 05:58
Default Non dimesionalised length
Pritam Gole
pritam.gole is on a distinguished road
If length in the code is considered as 3, then x' = x/L can't go from 0-3. It should vary from 0 to 1. But, in all the code it is considered as 0 to 3. Please help me out to understand it.
pritam.gole is offline   Reply With Quote
Old   March 6, 2020, 08:47
Default Shock Capturing(MacCormack) - John D Anderson
NotSteve
CrushedToucan96 is on a distinguished road
Thank you so much!
Im' facing just about the same issue as mentioned above. Temperature goes negative after 25 timesteps causing dt (Adaptive) and Mach number go complex. Isnt there a solution to this? Anderson hasnt done any sort of calculations for validation
CrushedToucan96 is offline   Reply With Quote
Old   March 8, 2020, 10:45
Default Shock caputring
NotSteve
here is my code
Hey i went through your code and whilst all looked fine there were some portions that i quite wasnt able to wrap my head around. One of those things were your steady state static pressure plot [1600 timesteps] for no artificial viscosity. Although there wasnt any smoothening which is expected the oscillations seems to be too low it almost quite resembled the analytical results. I have attached the plot i got for the same conditions and it quite matches with the book [Ref Shock.jpg & Shock_Anderson.jpg] . Another thing that i found out was your J2 formulation where you seem to have opted to use the bigger formula [Ref J2Formulation.jpg] , which conforms to the 'pure' form of the flux terms, There seems to be a typo in the log(dA/dx) part which which should have been forward differenced for the predictor part and rearward for the corrector part. [Ref J2Formulation_typo.jpg] . Making this change forces us to update J2 only in the inner nodes [ where i = 2:n-1] . I still get the negative temperature error after correcting this but thought you should know about this. Let me know if you've found a solution to this.
anderson, artificial viscosity, cfd, maccormack, shock capturing
Bow Shock Capturing Ronak Gupta Main CFD Forum 6 April 22, 2013 03:51
MUSCL shock capturing on high aspect ratio meshes vijay_paul Main CFD Forum 1 September 29, 2012 01:16
Problems with ansys 12 multizone method jflacerda ANSYS Meshing & Geometry 2 November 19, 2009 12:31
Shock in nozzle - dangerous? Christian Main CFD Forum 1 May 8, 2006 13:48
Has the pressure correction method problems? X. Ye Main CFD Forum 17 September 1, 1999 17:14
