How to compute lift and drag coefficients for flow past a fixed cylinder?
Like Tree1Likes
  • 1 Post By agd
Old   May 11, 2016, 02:47
Default How to compute lift and drag coefficients for flow past a fixed cylinder?
antonella.longo@ingv.it is on a distinguished road
I am trying to compute the drag and lift coefficients for the flow past a fixed cylinder. For this I need to compute the viscous and pressure forces at the wall of the cylinder. How to compute the viscous stress forces at the surface of cylinder? Since at the surface of cylinder the velocities are set to zero does it mean that viscous stresses are zero?
antonella.longo@ingv.it is offline   Reply With Quote
Old   May 11, 2016, 15:35
agd
agd is on a distinguished road
The viscous stresses are related to the velocity gradient tensor. The viscous stresses on the surface will be given by the dot product of the surface normal with this tensor. Zero velocity at the wall is not the same thing as zero velocity gradient at the wall. Perhaps the Wiki on this site would be of help?
FMDenaro likes this.
agd is offline   Reply With Quote
Old   May 11, 2016, 18:26
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
no, not at all ... I don't know if you are working in 2d or 3d, however you have to integrate the deviatoric stress tensor which is 2*mu*Grad v. You can see it involves derivatives along the normal direction to the wall that do not vanish
FMDenaro is offline   Reply With Quote
coefficients, drag, fixed cylinder
Unsteady Flow past circular cylinder-Re=100 (fluctuating drag and lift co-efficients) Vino Main CFD Forum 0 April 10, 2014 10:39
Can fluent get the lift and drag coefficients of the two walls (in different directio yuyuxuan FLUENT 8 January 10, 2014 21:13
Flow past rotating cylinder: Problem with ForeCoeffs raf1111 OpenFOAM 1 December 16, 2013 10:45
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 19:31
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 15:45
